misfire cylinders 6-10
13K views 14 replies 7 participants last post by  J70SGN
#1 ·
Hi guys got a bit of a misfire problem.
Car has 101k miles.
Just had bank 1 O2 sensors renewed as they were throwing up codes and the CEL light.
Now the car seems to have developed misfires on bank 2 along with the bank 2 O2 sensors flagging up codes.
Specifically codes p2629 p0300 p0306 through to p0310.
My thinking is that because bank 2 O2 sensors are the same age as the bank 1 sensors that were replaced haven't been replaced they are completely gone and causing the misfires. Any help would be greatly appreciated.
Cheers
Scott
#3 ·
Where abouts is this ionic module located?
She is due a spark plug change and vehicle check. Oils not due for another 2k miles it ill be getting that changed at the same time as the plugs
#4 · (Edited)
They are on the top front of each head under that black plastic dome shape cover. You have one for each bank. Swap them and see if the misfires move over to the other side like Troy suggested.
http://www.realoem.com/bmw/showparts.do?model=NB93&mospid=48807&btnr=11_3687&hg=11&fg=15
It's under #15 and the sensor is #20.
#5 ·
Dang man. At least you didn't get misfires on all 10 cylinders like mine.
#8 ·
View attachment 470562 it is in this pic
If your engine didn't fail. Start changing your oil every 5k miles. Or you will be calling me soon for a motor. You don't want to call me. ;-)
Sucks you can't take it apart and fix it! It's one of those consumable parts. No screw holes anyone on the dang thing!
#7 ·
FYI: Troy is most likely right. Just had the same problem a few weeks ago!
#15 ·
Hey guys changed the modules ran away fine then limp mode came on. getting 306-310 and 300 then it clears it's self then comes back. Think its still got something to do with the 2 O2 sensors I've yet to replace have them on order. Will keep you posted
