Alright guys. I haven’t posted here in years. Due to me always knowing how to fix my own cars. But this time? Definitely going to need some thoughts and insight to see if this can be figured out. All of your help will be greatly appreciated.
So cylinder 5 misfires on cold starts.
once car is warm runs totally fine. Here’s what I’ve done so far.
replaced spark plug, ignition coil, injector. Found vacuum leak on throttle body on that cylinder. Fixed that also. Replaced ionic sensors on both banks. I’ve also done a leak and compression test and it was perfect.The only code I have is misfire cylinder 5. Nothing else. I’ve also swapped plugs, coils etc misfire did Not follow.
the only thing I can think of at this point. Is vanos solenoids on that bank. They’re the originals. I have not performed a vanos test yet. But that’s my next step. I’ve attached the leak and compression test as well.
So any idea would be great!
