1 - 7 of 7 Posts
I can code these options, pm me for more info.
* Euro Corner Delete
* Digital Speedometer on Cluster
* Roll up the window while holding lock on remote
* Eliminating the ignition key dong
* Folding mirror while holding lock on remote
* Eliminating iDrive accept message on pre 09 units.
*Unlock doors when car is turned off... No more double pull on handle needed!
* (There are many requests for removing the seatbelt dong as well, however, I found out that it was never confirmed how the air bag will react and the coding is done under the air bag module so we currently will not be offering that coding for your own safety!)
Discussion Starter · #2 ·
Updated list
NOTE: some options don't work on certain models. feel free to email me at [email protected]
* DVD in motion on pre 09 units.
* Unlock doors when car is turned off... No more double pull on handle needed!
* Acoustic seat belt warning disable. Do this at your own risk.
* Fog + high beam flashing
* Fog + Bi-xenon flashing
* Double impulse Hazard lights
* Alarm coding
* Aftermarket LED light error removal
* Adaptive headlight error removal
* Any light as a welcome light.. My low beams turn on when I unlock the car, but you can chose any light if you want..
* TPMS decoding if you are track wheels or not running tpms at all.. no more error light
Videos:
http://www.youtube.com/watch?v=ZFCcR19PeeA
http://www.youtube.com/watch?v=rU_iQ2mJo8s
http://www.youtube.com/watch?v=3SMhNBdJC7E
http://www.youtube.com/watch?v=ihwMwcoR6ik
http://www.youtube.com/watch?v=a3cJlEMZP08
http://www.youtube.com/watch?v=WIsWo3a_b_s&hd=1
how much?
Updated list
I can help you code these options, email me at [email protected]
or txt me at 3059928405
* Video in motion on all units CCC and CIC
* Alarm coding like panicmode or louder chirp
* LED tail light retrofit
* Disable windows safety feature, so when you open the door the window roll up normally.
* Brake Force Display light with regular Brake light, in short words the rear fog light will light up when you brake.
* Engine Start without having to press the brake pedal
* Comfort Tailgate
* Allow AE's to be full bright with lights one.
Disc: Not all options are available in your model, but most of them do..
1 - 7 of 7 Posts
