Got some picture taken while I am replacing the master clutch cylinder:
First Get the following parts:
Master Clutch cylinder, Slave Clutch cylinder
Part Number:
Master
Slave
First Cover off
Speaker Wire Remove
Then Air Duct off
Master cylinder view
Nuts to remove, very tight near the steering column
Outside the firewall
Remember to take some cloth to cover up before removing
Since it is too tight to work on, I need to remove the clutch fluid unit to gain access
Then pull the master cylinder out
Then reverse the removing steps
Next to install the slave cylinder
Part Number:
Master
Slave
First Cover off
Speaker Wire Remove
Then Air Duct off
