1 - 13 of 13 Posts
Can someone in Europe find out what the specs of the M5 Winter Wheels and Package are?
Specifically, the dimensions of the wheel - I've been told they're 18" and what tyres they put on it?
They come standard with Michelin Pilot. Cost is equal to 3300 EUR.
offsets the same as e39 M5?
Ashok Arora said:
Anybody know if the offsets for the new wheels are the same as on our current cars? I have a set of winter tires & wheels I'd like to use if I can, since my car is leased and I won't be handing them over to a new owner. Thanks!
Re: offsets the same as e39 M5?
E39 winter wheels were ET:20 all round
E60 Winter wheel is ET:20 rear and ET:14 front
BG said:
It broke down, mmmmmm I sure hope it's one of the pre-production examples, 'cause if it's a normal production one....
it was indeed a pre-production spec car for press.
according to the journalist that drove the car at the time. it was the bad oil pump that caused the problem.
Yes, it was the oil pump, but I do not belive it was a preproduction car ... It was 2 weeks old (2500 km), so I guess it was a normal production car.
One thing you have to remember the centre bore on the e39 is 74.1mm and the centre bore on the e60 is 72.6mm. You will need to get hold of some of the small rings before you mount the wheels otherwise you will get vibration.
The offsets are fine, slight difference but nothing that will cause you a problem with winter wheels.
Cheers
1 - 13 of 13 Posts
