1 - 13 of 13 Posts
i have a 2005 m5 and i have difficulties when shift from 1-2 and 3-2 gears.i have a new clutch and flywheel.my dealer found 4fA0 and 4f80 fault code and we changed both cluth and flywheel,but the problem remains the same and code 4f80 is still there.please any info.
Unfortunately.....
You have an early build SMG tranny, which frequently fail. You need a whole new tranny. 'Hope your warranty is still valid. Good luck.
Wow, I hope you get it fixed. How long would it take for a new tranny to be installed?
What??
Dan, are you 100% sute on that?
In anycase, if that is the case I am suire it will be taken care of on goodwill.
Gustav
I don't understand your question. This Board is full of dozens of reports of early build ('06 and prior) SMG tranny failures; many times multiple failures on the same car. The OP is a new member. I suppose I could have replied "Do a search"; but thought my post would save him some time.
'Glad you think BMW AG is full of "goodwill". That has NOT been my (and many others) experience with BMWNA (which, thank goodness for the OP if his car is out of warranty, would not be involved with a European owner).
The question was if you are totally sure on that :)
SMG have in ALL cases Ive read on the board been covered by goodwill or warranty.
Have you stole Martin's GTboard.com DVD2 yet? :thumbsup:
SMG 2nd gear problem
I have the same problem now the 2nd Gear want shift and a massage of trans. malfunction is on-board every time i try to shift to the 2nd gear it jumps directly to 3ed or back to 1 skipping 2nd ,, pls inform me how did u solve ur problem ? my car is already out of warranty and i paid too much with no results...
if u guys have any thing to send me pls do on [email protected]
1 - 13 of 13 Posts
