1 - 10 of 10 Posts
here is one for you all . bmw m5 e39 in first gear bang the power down its perfect ,second gear foot to the floor and the car kangerooos up to say sixty 3rd gear perfect 4 5 6 gears perfect so second is the problem it does the same when traction on and off eg dsc i have had the car 16 years and its done 77k cheers
Have you checked your engine mounts as a simple check?
Simon
Simon there is a few things that need doing the car is 20 in march the weird thing is why only second and if I press the pedle slowley it's ok it's like the abs is cutting in in second gear but no others
Fuel cutting out? Search fuel pump. When I replaced my fuel pump it fixed the “hopping”
1 - 10 of 10 Posts
