1 - 20 of 65 Posts
Production Versions:
DE91: European-spec (LHD), 10/98-06/03
DE92: European-spec (RHD), 10/98-06/03
DE93: North American-spec, 09/99-06/03
History:
What makes the E39 M5 unique?
The E39 M5 is the BMW M-developed version of the E39 5 Series sedan. It is powered by the S62 V8 engine, a high-performance development of the standard production M62 unit. It also features an M-tuned chassis as well as M-designed interior and exterior cosmetic items.
When was the E39 M5 first introduced?
The E39 M5 was first introduced at the 1998 Geneva Motor Show though production did not begin until October of that year.
Where was the E39 M5 produced?
Unlike both previous iterations of the M5 (which were hand-assembled at BMW M GmbH in Garching), the E39 M5 was produced on the normal E39 5 Series assembly line at the Dingolfing factory, outside of Munich.
Was a Touring (station wagon) version of the E39 M5 ever produced?
Although an E39 M5 Touring was considered and at least one prototype was constructed (in Titanium Silver with a Black Exclusive leather interior), BMW M decided not to produce an E39 M5 Touring due to financial considerations.
Production Data:
How many versions of the E39 M5 were produced?
BMW M produced three versions of the E39 M5: Two European-specification models (left-hand drive and right-hand drive) and one North American-specification version.
How many of each version of the E39 M5 were produced?
ECE (LHD): 7,895 examples produced from 10/98 thru 06/03
ECE (RHD): 2,595 examples produced from 10/98 thru 06/03
NA (LHD): 9,992 examples produced from 09/99 thru 06/03
What changes were made to the E39 M5 during the time that it was produced?
Though there were no major mechanical alterations to the E39 M5 during its entire production run, there were a number of equipment alterations that appeared with the 2001 model-year M5 (from 9/00 production). These include:
-Revised headlight design incorporating illuminated "Angel Eye" rings
-"Jeweled" tallight design
-Park Distance Control sensors in the front bumper (previously in rear only)
-Thicker three-spoke M steering wheel identical to the one fitted to the E46 M3
-Grey instrument faces
-Solar sensor for standard automatic climate control
-Revised navigation/audio unit with larger (6.5-inch) monitor
-Rear head protection airbags added
-Second-generation M Mobility tire repair system in place of earlier version
-Available M Audio System with special tweeters, Kevlar/carbon coaxial speakers and two subwoofers behind the rear console
-Alcantara headliner included with Extended Leather interior (previously only included with Complete Leather)
For the subsequent two model years, changes were limited to the addition of new exterior colors (from 9/01 production) and the upgrade to a DVD-based navigation system (from 9/02 production).
Drivetrain:
What makes the S62 enigne unique?
Though based on the same basic architecture as the regular aluminum-block 4.4-liter M62 powerplant fitted to the E39 540i, the S62 V8 engine has been extensively modified by BMW M in the following areas:
-Increased bore to 94mm (from 92mm) and increased stroke to 89mm (from 82.7mm) for a total displacement of 4,941cc (up from 4,398cc).
-Increased compression to 11.0:1 (from 10.0:1)
-Individual electronically-controlled throttle bodies for each cylinder with M Driving Dynamics two-stage control (via the "Sport" button)
-Double VANOS continuously-variable valve timing on both the intake and exhaust strokes
-Siemens MSS 52 Motronic digital engine control system
-Three-layer steel head gaskets
-Dual air induction system
-Modified cylinder heads
-Hollow camshafts
-High-capacity water pump
-Duplex chain drive for the intake cams
-Oil-cooled pistons unique to each cylinder bank
-G-force-sensitive lubrication system with two scavenging pumps, one for each cylinder bank
-Coolant to oil heat exchanger for engine cooling
-Free-flow exhaust with dual catalytic converters and four exhaust tips
The S62 engine produces 400 hp (DIN) or 394 hp (SAE) at 6,600 rpm and 369 lb/ft of torque at 3,800 rpm. It is easily identified by its large central cam cover that carries the "M" logo and is further inscribed with "BMW M Power" against an artificial carbon fiber background.
What kind of gearbox does the E39 M5 have?
All E39 M5s are equipped with a Getrag Type D six-speed manual gerabox with the following ratios: 4.23 (1), 2.53 (2), 1.67 (3), 1.23 (4), 1.00 (5), 0.83 (6). The transmission is mated to a 2.81:1 rear differential. Though this same gearbox (and ratios) was also offered in the E39 540i, the E39 M5 drivetrain has two unique components: The clutch is reinfoced to cope with the added torque of the S62 powerplant and the rear differential features a limited slip device (25 percent maximum locking).
Is the E39 M5 equipped with electronic stability control?
Yes, the E39 M5 was the first M Series automobile to feature BMW's Dynamic Stability Control (DSC) which incorporates the Automatic Stability Control (ASC) traction control system but can also apply braking force to any wheel in order to help correct for understeer or oversteer. The system can be de-activated via a console-mounted button.
How do the European-specification and North American-specification E39 M5s differ mechanically?
Aside from minor mechanical differences required to meet specific safety and emission regulatons in each market (such as positioning the exhaust catalysts closer to the engine on North American-spec models), E39 M5 is essentially the same worldwide. One notable excpetion is the exclusion of the European-spec M5's two-piece front brake rotors on the North American model.
Chassis:
How is the E39 M5's suspension different from that of a regular 5 Series?
The suspension of the E39 M5 shares its basic aluminum-intensive MacPherson strut/multi-link design with that of the V8-powered E39 5 Series models but incorporates several specific changes from BMW M:
-Specific spring rates with reduced spring height (0.9-inches shorter than standard E39 springs, 0.1-inches shorter than M-Technic E39 springs)
-Specific shock valving
-Thicker anti-roll bars front and rear
-Polyurethane auxiliary springs in place of rubber units
-Steel balljoints in place of rubber rear suspension bushings
How does the E39 M5's steering system differ from that of other E39 5 Series models?
Like all V8-powered E39 5 Series models, the E39 M5 is equipped with a recirculating-ball steering system. However, the overall steering ratio has been reduced to 14.7 from 17.9. In addition, the E39 M5 features Servotronic vehicle-speed-sensitive power assist that provides two levels of resistance controlled via the console-mounted M Driving Dynamics button (informally known as the "Sport" button).
What size brakes does the E39 M5 have?
The E39 M5 is equipped with four-wheel vented disc brakes measuring 13.6-inches in diameter in front and 12.9-inches in diameter in the rear. On European-specification models, the front rotors are of a "floating" two-piece design for better heat dissipation. ABS is standard.
What are the factory wheel and tire sizes for the E39 M5?
All E39 M5s are fitted exclusively with 18-inch M Parallel Spoke II cast alloy wheels featuring a Satin Chrome finish. These wheels, which measure 8x18-inch (front) and 9.5x18-inch (rear) and wear staggered 245/40ZR18 (front) and 275/35ZR18 (rear) tires, are specific to the E39 M5.
Cosmetics:
How is the exterior of the E39 M5 distinguished from that of the regular 5 Series?
The E39 M5 is equipped with several unique exterior cosmetic items that distinguish it from other 5 Series models. The front fascia features an enlarged grille with wider chrome trim around the "kidneys" as well as a unique M-Technic airdam with mesh over the central intake. The rear of the E39 M5 can be distingished by a small body-color lip spoiler (deletable upon request) as well as a unique rear bumper and lower diffuser that incorporates two pairs of dual exhaust outlets. There are also M-designed rear-view mirrors (which fold up electrically), the unique 18-inch M Parallel Spoke II alloy wheels and three "M5" badges that adorn the exterior of the car, one on each of the side mouldings and a third on the trunk lid. Most E39 M5s were equipped with high-gloss Shadowline (black) window trim though the chrome trim from the standard E39 could be specified as a no-cost alternative in most markets. All E39 M5s have clear turn signal lenses.
What distinguishes the interior of the E39 M5 from that of a standard E39 5 Series?
Though the interior of the E39 M5 shares its basic design and architecture with that of the standard E39 5 Series, it is distinguished by several unique items.
All E39 M5s are equipped with power and heated M sport seats with adjustable lumbar support and a three-position memory on the driver's seat.Two distinct upholstery and trim styles were offered: "Sport" and "Exclusive" (later renamed "Luxury" for the North American market). The Sport interior was offered in the following combinations: Alcantara upholstery and door panels with Nappa leather bolsters and aluminum-look interior trim (not available for the U.S market), Nappa Point leather upholstery and door panels with Nappa leather bolsters and aluminum-look interior trim or Nappa Point leather upholstery and door trim with Nappa leather bolsters and Bruyere Club wood interior trim. The Exclusive interior included pleated Nappa Heritage leather upholstery and door trim with Bruyere Club wood interior trim or pleated Nappa Heritage leather upholstery and door trim with Burl Walnut wood interior trim. In addition, any of these interiors could be trimmed in either Extended Leather (leather on the door pulls, door armrests, center console, center armrest and sun visors) or Complete Leather (leather on the door pulls, door armrests, door panels, center console, center armrest, sun visors, dashboard, glovebox door, upper door trims and lower B-pillar plus Alcantara on the headliner, A-pillar, upper B-pillar, C-pillar and rear parcel shelf), depending on the market and production date.
Two different airbag-equipped three-spoke M steering wheel designs were offered in the E39 M5, both with M tri-color stitching on the rim and buttons for the audio system and cruise control on the upper spokes. The early version (thru 8/00) resembles the wheel offered in the some E36 3 Series, E38 7 Series and E39 5 Series models but is smaller in diameter (375mm versus 385mm). The later version (from 9/00) is identical to the wheel used in the E46 M3 and features a different spoke design and a thicker rim.
Also unique to the E39 M5 are special instruments featuring aluminum bezels, red needles, a 300 kph/180 mph speedometer incorporating the M logo, an oil temperature gauge under the tachometer in place of the usual economy meter and a an LED variable redline that extinguishes as the engine reaches normal operating temperature. Gray gauge faces were introduced for the 2001 model year (from 9/00 production).
Finally, the E39 M5 is equipped with an M footrest for the driver, an oval-shaped auto-dimming M rear-view mirror, special door sill plates featuring the "M5" logo and an illuminated M shift knob also incorporating the "M" logo (made of either leather and aluminum-look trim, Bruyere Club wood or Burl Walnut wood).
What options were available for the E39 M5?
Unlike the previous two iterations of the M5, the E39 M5 was very well equipped in all markets and included most of the available E39 features as standard equipment including Xenon headlights, headlight washers, power and heated front seats with three-position memory for the driver, power tilt and telescoping steering column, automatic climate control, cruise control, extended on-board computer and a premium audio system. Options for the E39 M5 varied from market to market but generally included various types of leather upholstery and wood trim, power moonroof (standard in North America), on-board navigation (standard in North America), Park Distance Control, power rear sunshade (not available with Complete Leather trim), M Audio System (from 9/00), split-folding rear seats and rear side airbags (standard in North America from 9/02).
How do the European-specification and North American-specification E39 M5s differ cosmetically?
Aside from minor differences in lighting and instrumentation mandated by the different markets, all E39 M5s sold worldwide are essentially the same in terms of appearance.
Special Versions:
Were there any special factory editions of the E39 M5?
No, BMW M never produced any official factory special editions of the E39 M5.
Color and Upholstery Selections:
Exterior Colors:
Alpine White III (300), Imola Red (405), Jet Black (668), Titanium Silver metallic (354), Avus Blue metallic* (276), Le Mans Blue metallic** (381), Anthracite metallic*** (397), Sterling Grey metallic**** (472), Silverstone metallic*** (425), Blue Water metallic**** (896), Royal Red metallic*** (390), Chiaretto Red metallic**** (894), Oxford Green metallic (324), Carbon Black metallic (416)
*thru 02/00
**from 03/00
***thru 08/01
****from 09/01
Interior Colors (Sport):
Black M Alcantara/Nappa leather (not for U.S.), Black Nappa Point leather/Nappa leather, Le Mans Blue and Black Nappa Point leather/Nappa leather, Imola Red and Black Nappa Point leather/Nappa Leather, Silverstone and Black Nappa Point leather/Nappa Leather
-Sport interiors could be equipped with either aluminum-look trim or available Bruyere Club wood trim.
-Sport interiors could be equipped with either Extended Leather or Complete Leather (thru 08/00 in North America).
-Extended Leather includes leather on the door pulls, door armrests, center console, center armrest and sun visors
-Complete Leather includes leather on the door pulls, door armrests, door panels, center console, center armrest, sun visors, dashboard, glovebox door, upper door trims and lower B-pillar plus Alcantara on the A-pillar, upper B-pillar, C-pillar and rear parcel shelf
-An Alcantara headliner was included with the Complete Leather interior and available as a no-cost option with the Extended Leather interior from the start of production, then made standard with all Sport interiors as of 09/00.
Interior Colors (Exclusive/Luxury):
Black Nappa Heritage leather, Caramel Nappa Heritage leather, English Green Nappa Heritage leather (thru 08/00 for U.S. market)
-Exclusive Interior is known as the Luxury Interior in North America as of the 2001 model year (09/00 production)
-Exclusive/Luxury Interiors could be equipped with either Bruyere Club wood trim or available Burl Walnut wood trim
-Exclusive/Luxury Interiors could be equipped with either Extended Leather (available thru 08/00 in North America) or Complete Leather.
-Complete Leather includes leather on the door pulls, door armrests, door panels, center console, center armrest, sun visors, dashboard, glovebox door, upper door trim and lower B-pillar plus Alcantara on the headliner, A-pillar, upper B-pillar, C-pillar and rear parcel shelf.
-An Alcantara headliner was included with the Complete Leather interior and available as a no-cost option with the Extended Leather interior from the start of production, then made standard with all Exclusive/Luxury interiors as of 09/00
:M5launch: :M5launch::M5launch::M5launch::M5launch:Copied from M registry
Excellent summary! However, I thought that the standard differential ratio is 3.15:1 ? I think you may have the value for the 540i stated instead.
Artificial carbon fiber background?? I thought it was real carbon! :grrrrr:
-Matthew
I noticed that as well. The 2.82 was used in most 540s.
I'm not sure about all the facts but wanted to have some ionfo here. It would be nice to eventually compile all the facts and remove the falicies...
Didn't our engines go thru some Oil Ring change as well?
:cool:
B
Guest
:cool:
I agree, the data you posted is a great resource, and overall very accurate. It would be nice to have static fact section on the board.
Cheers.
Cheers.
Yeah, how about it Gustav? Still looking for improvements to the board? This gets my vote too!
Good find Ocean-Side..
Mine too :M5thumbs:
Ocean side,
I like the idea too of having a reference section on the broad. Thanks for your post. I saw the other, later, post like yours just a minute ago. Looks like you were the "vu" and chunpng was the "deja" Okay, terrible joke.
Beastpower,
Can you post or PM me the cost of the M Power CF panels and M logo you have shown above. The reason I ask is because someone has scratched mine!!! Very few people get to go under the hood like that, so I'm not sure when it happened--maybe one of the tech inspectors at the track(?). Anyway, being sorta of compulsive, maybe I'll replace them. Thanks!
Anita
yeah stock m5 diff is 3.15, though diff for the 540i 6 speed was 3.45.
Great info Sam. :thumbsup: I was always looking for the diferences between the standard E39 and the M5. Voila you come through. Very cool, this is a keeper.
Regards
:cheers:
T.
I finally know what interior I have in my 2000. I've been calling it extended leather, but it's the complete leather. Very informative. Thank you.
Just when you thought you had it down....
Hey, rennen-
See if this serves to clarify or confuse. It's the 2001 product bulletin that explains the difference between '00 and '01 model years. This was the ONLY source that definitively showed that '00 cars were the only ones with true leather dashes and door tops. Hope it helps!
To paraphrase, in 2000, two interior levels were offered: "Sport" and "Exclusive" (or Sportiv und Exclusiv), and both were available either in Extended Leather (now Standard) or All Leather (with the leather dash). Exclusive became Luxury, and the All Leather went away in 2001. Most Sport interiors came with the Extended Leather, and many Exclusive interiors came with All Leather.
When I ordered my car, both the Alcantara headliner and the All Leather interior were no-cost options.
-Dave
B
Guest
Anita said:
Beastpower,
Anita
You have a PM. :)
Re: Just when you thought you had it down....
Dave,
Thanks for that document! I've pieced together the changes over the model years '00 to '01, but it's nice to have the real story in one place like this, and I've learned a few new things. For example, I didn't realize that the '00 rear airbags didn't incorporate HPS.
Chuck
Discussion Starter #17 (Edited)
More facts...
M5 Colors Projected
M5 Colors ACTUAL
Click Here for M5 Wallpaper and Screen Savers
Specifications
Year 2001 Origin Munich, Germany
Make BMW Base Price $69 400 USD
Engine & Transmission Body / Chassis
Position Not Available Drive Wheels Front Engine / RWD
Configuration V8 Curb Weight 1795 kg / 3957 lbs
Valvetrain DOHC 4 Valves / Cyl with Double VANOS Length 4784 mm / 188.3 in
Displacement 4941 cc / 301.5 cu in Width 1801 mm / 70.9 in
Power 293.8 kw / 394.0 bhp @ 6600 rpm Height 1412 mm / 55.6 in
Torque 498.94 nm / 368.0 ft lbs @ 3800 rpm Wheelbase 2830 mm / 111.4 in
Bore 94.0 mm / 3.7 in Front Track 1514 mm / 59.6 in
Stroke 89.0 mm / 3.5 in Rear Track 1527 mm / 60.1 in
Redline 7000 rpm Steering Speed Sensitive Recirculating Ball
HP / Liter 79.74 bhp per litre Body / Frame Unit Steel
HP / Curb Weight Front Brakes Vented Discs w/ABS &
Vacuum Assist
Gear Type Getrag Type D 6-Speed Manual Front Brake Size 345 mm / 13.6 in
1st Gear Ratio 4.23:1 Rear Brakes Vented Discs
2nd Gear Ratio 2.53:1 Rear Brake Size 328 mm / 12.9 in
3rd Gear Ratio 1.67:1 Front Wheels F 45.7 x 20.3 cm / 18.0 x 8.0 in
4th Gear Ratio 1.23:1 Rear Wheels R 45.7 x 24.1 cm / 18.0 x 9.5 in
5th Gear Ratio 1.00:1 Front Tires 245/40ZR-18
6th Gear Ratio 0.83:1 Rear Tires 275/35ZR-18
7th Gear Ratio Not Available Front Suspension Not Available
Final Drive Ratio 3.15:1 Rear Suspension Not Available
Performance
Top Speed 249.4 kph / 155.0 mph 0 - 60 mph 4.8 seconds
0 - ¼ mile Not Available 0 - 100 mph Not Available
Lateral Acceleration Not Available EPA City/Hwy 13 / 21 mpg
What happened to all those weird and wild projected colors? Maybe they should bring them back for the new E60 M5 help distract us from any design issues we may have!!!
Anita
How true, Anita....
I think the "proposed" Lavender Purple was chasing an odd color craze that began around 1996. Every third Taurus & S-10 was that color for about 2 years. By 1999, buyers woke up and demand completely dried up.
1 - 20 of 65 Posts
