1 - 9 of 9 Posts
Still learning and new to the M5 stuff---What do these run new? Simple bolt on or do they need welded? HP increase? What kind of sound difference do these make?
Dinan Cars - Free Flow Exhaust (E60) M5
The Dinan M5 exhaust system provides maximum flow characteristics for optimum power gains while producing a civilized, yet very sporty exhaust note that is appropriately aggressive at wide open throttle. And there's none of that irritating low rpm ''drone'' that is common with so many aftermarket mufflers. The mufflers are manufactured from 100% 304 stainless steel inside and out for maximum resistance to corrosion and nearly a 30% reduction in weight, eliminating over 20 lbs.
The four 3.5'' diameter polished stainless steel tips not only give the car a more aggressive look but also feature Dinan's new ''Cool Tip'' design that effectively reduces temperatures in order to minimize radiant heat that can effect body work over time, as well as avoid discoloration of the tips themselves. The Cool Tips also avoid the possibliity of a nasty burn while loading items in the trunk. Employing the principle of rarefaction, the design features an inner and outer tip with a vent at the base. When a positive pressure wave travels to the end of an open pipe and is ultimately expelled into the atmosphere, a rarefaction or momentary drop in density of the surrounding air is created behind it. This momentary drop in the density of the air surrounding the pipe's exit creates a vaccuum, pulling the air from the surrounding area to fill the void. The vent at the base of each outer tip then enables air to be drawn in, effectively cooling the tips
Utilizing the factory brackets and hangers, the Dinan exhaust mounts in a factory-like fashion for a perfect fit and clean installation.
Specifications
Labor Hours 1.6
Emission Status 50 State Emissions Legal
Max HP Gain 9 @ 8000 rpm
Max Torque Gain 6 lb-ft @ 8000 rpm
Included Notes Included Item Details
D660-0009A
This item is worth 3 point(s) towards your Dinan Badge.
Price: $2,899.00
hope that helps!!!
Specifications
Labor Hours 1.6
D660-0009A
Price: $2,899.00
hope that helps!!!
Yes, that helps me greatly---I am ready to go with an aftermarket exhaust, just not sure which one. I have been browsing Youtube non-stop listening to as many vids as I can of different systems. I really like the Dinan...
Discussion Starter · #8 ·
sounds good! if you have any questions or inquiries dont hesitate to ask!
1 - 9 of 9 Posts
