I notice that the m-audio subs have a 4 pin connection,and i guess the regular non-dsp amp has only 2 wires? if so,is it possible to split these 2 into 4 so that it can fit in the m-audio subs' connector?just had a look as well,the rear shelf speaker wires have 2 sets per side ie bigger push in connector 4 wires not just 2.
rear subs have a different loom connector. cant see the fronts properly.
You'd might as well get the bsw speaker upgrade kit. Less work, loads better than factory speakers and probably cheaper.I was wondering about the possibility of having the M-audio subs wired to a non-DSP system,does anyone have an experience in this? is it possible,and if so what is required to have it work ?
