1 - 5 of 5 Posts
Hi guys,
I'm lowering my car. Using H&R springs 29143.
Was wondering if I need spacers for it aswel.
I'm putting on 20x8.5 with 255-35-20frt. 20x10 with 285-30-20
rear. The offsets for the front is 20 and 25mm rear.
Help me out guys.
i had to. i should have asked like you did but instead i learned the hard way and chewed threw a new set of tires. btw, im dropped with coils and much lower than springs will give you so it may be a bit different.
im using 12mm all around, looks good.
How does this affect the algorithm used for the EDC? I'm on 20s too, and considering lowering it. I'm hesitant; however, because of the EDC program.
Ben
Coils do affect the EDC by disabling the EDC Module with by a bypass provided by some companies, espcially KW's. Your gonna want at least a 15mm spacer on the front. GL
1 - 5 of 5 Posts
