same here, warning at 1/4 level between the markings when shutting off the
engine, this is an intended pre-warning to make the driver AWARE -
because, if you intend to take the car on a high-speed-ride for a long
distance, like 500 km on a german 'autobahn' with no speed limits, then
oil-consumption might rise to 1/2 liter and above, depending on the circumstances - this cud lead to a critical low-oil situation and you do NOT
wish to see a 'low-oil-warning' at high-speed, do you
so, it seems to be intended that a low-oil-warning is given 'early', just
to make you aware !!! :byebye: for normal driving there is no problem
as long as the oil-level is above the minimum-mark but it cud be IF you take
the car for long-distance high-speed run - 'does this make sense' ???
brgds
Karl
