1 - 20 of 33 Posts
Well gang. The Porsche is up for sale and I wanted an older M5 or M3. There was one on Ebay with to many goodies to pass up.
It is in Houston. SO I may ask some one of the Houston gange to give it a once over if possible. It would be to funny if several of you swarmed him for an inspection hehehehehehehe.
Here is what it has:
2001 BMW M5 59k miles
Black with Caramel interior
Navigation system
M Bass stereo upgrade
K40 Stealth with radar jammer. $1400
Shroth 4 point harness. $270
Engine:
Eurobahn Carbon fiber high volume plenum $2200
Increase air volume by 10% decrease air temperature by 20-28 degrees F.
Eurobahn software $350
Increase of 8 horsepower over Dinan Stage 3
Dinan Cold Air intakes $ 2000
Dinan high volume air mass sensors $1200
Air temperature relocation kit $150
Supersprint headers and connector pipe $2900
Supersprint X pipe $475
Supersprint Magnum Series exhaust $2200
Dyno test shows 440HP at the crank. Performed and documented by Bavarian Hyper Sport
Best 1/4 mile out of 3 runs was 12.80 seconds (non pro driver)
Transmission:
UUC Short shifter kit $375
UUC transmission mounts $180
UUC Lightweight flywheel kit. (24 pound aluminum flywheel with 850csi friction plate) $3500
Dinan 3.45 differential $2800
Suspension:
K&W Variant II Coilover Kit (Adjust ride height and stiffness) $2500
Eibach oversized swaybar kit front and rear $900
Dinan strut tower brace front and rear $900
Brakes: Brembo Big Brake kit with Ferrodo pads and ATE Super Blue DOT4 Race brake fluid $3200
Wheels:
Hammon 19 inch Pro Series II $4500
Tires :
Bridgestone SO3 Front 245/35 ZR19 Rear 285/30 ZR19 Brand new condition $1300
All maintenance and performance modification were performed by Momentum BMW and Bavarian Hyper Sport.
All fluid changes done prematurely
Oil changes done at 4k miles
I think you mean 8 HP over Dinan Stage 2. Dinan stage 3 claims 620+ HP
Navigation system
Engine:
Transmission:
Suspension:
Wheels:
Tires :
Wow, that looks really sweet Tim, but I bet you wish it was Imola lovelove . We conversed a bit back when I was buying my M5 in Denver, so it's good to see you're getting back into an M5 -- isn't this #3?
Cheers,
Chuck
I bought the one Mike looked at there in Denver -- 2001, 12k miles, one owner. That was in Feb2004, so now it has just turned over 26k miles (including the almost 2k mile trip home). The car (knock on wood) has been almost totally free of any troubles so far. It had an 02 sensor go bad just after I got back home, but since then it has had zero warranty claims...whoops, forgot about an exhaust hanger that needed to be replaced. I probably shouldn't even be talking about it since the warranty expires in late August. ;)
Ag02M5 said:
Hi.
Did you get the car? Looks like the auction is over and the reserve met.
Just curious. Definitely has the right parts!
R
Link?
Third time's a CHARM!
Tim W said:
Yes I did. It will be inspected in the next day or so. Than on to me if it is all good.
Welcome back, Tim!
Looks like you got a dandy there. Glad to have you back in the fold.
If you need an Imola fix and the Roadster's gone, I've got an Imola E38 740i Sport I could talk to you about...
Congrats, and good luck closing out the transaction.
-Dave
Discussion Starter · #17 ·
Josh, thats what I thought.
About the HP at crank vs. wheels etc. He has a different software package than Dinan. From what he said they ulocked a few areas that Dinan did not use. Apperently there was a "spike" of sorts at 5500 RPM and they leveled that etc. And heck you know that crank hp is justa calculation from wheel hp. Let alone accounting for ambiant temps and humidity blah blah
1 - 20 of 33 Posts
