61 - 80 of 313 Posts
What business does the SZL have with the DKG I wonder?
EDIT: Dumb question....steering position. ouich
Precisely.
Here's some brilliant work on the E84. I found the vast majority of E60 to be identical. This structure should give some frame of reference for the PT-CAN.
http://www.loopybunny.co.uk/CarPC/k_can.html
Already ordered wire taps so I'll be the guinea pig.
Since the byte string begins with the ArbID, all messages in a string come from a single component. First step is to identify ArbIDs then break the structure down.
Discussion Starter #62 (Edited)
All jobs required for DCT calibration/adjustment can be executed via tool32 at the absolute minimum. Toolset can access and control a module with a direct connection without relying on the rest of the car. Worst case scenario we will need to individually run the jobs without a fancy GUI like ISTA provides, but it will work. If we can make it work in toolset, we can make it work in INPA too. Technically, you could modify the VCM info or manually create a connection with ISTA and just give it e9x info for connection instead of the E60 info. If the physical wires are there, its just a matter of making everyone talk.
Physical plumbing of the air/oil cooler should be straight forward as well as a t-tap into the hot & cold side of the coolant system in the M5
I'd venture a guess and say that those signal ID's are uniform across the model range for at least the generic signals like RPM, VSS, brake signals, etc. Changing signal identities would call for complete reprogramming of the communication system as we know it.
That's kind of what I was thinking. All the actual calibration routines are built into the firmware of the modules themselves, so it's just a matter of getting EDIABAS to send the correct commands to the correct module.
I build a custom .IPS at one point to poke around the SMG a bit. I would think building an .IPS for DCT should be achievable as well, even with the graphics. As you said though, should be able to access it via the E9x menus.
Discussion Starter #64 (Edited)
Another thing to note....judging by the block diagram, PT_CAN is not directly wired from DKG to the OBD port - it goes through the Junction box. Were going to need a JB to be able to talk to DKG. D_CAN is the roadway to the JB, from there, JB puts you onto the PT_CAN - which means we will no longer need to trick ediabas into thinking hes talking to a e9x. We will simply wire a 2nd OBD port to the JBBF, from there ISTA will know what it what to look for depending what is on the bus.
Is this the "footwell module" on the E9x or a similar module to KGM? OBD to KGM is the path for us to SMG via PT-CAN, correct?
Discussion Starter #66 (Edited)
Technically it's the fuse panel electronics but it looks like it's serving as a pass through for CAN communication. If you look at the PT_CAN schematic, everything on PT is behind the JB.
Discussion Starter #68 (Edited)
Connection is not shown from DCAN to PT CAN. Either its controlled by the JB with transistors (likely) or it has constant continuity (unlikely). we need someone to do a continuity check from pins 1, 2, 33, & 17 to see if we will need a JB or not. If its simply a bridged connection we can omit the JB for a simple piece of wire.
Just dropping in to see how the progress is going :smile
As far as any real evidence has surfaced, Gintani is *planning* to do this on Tamirlan's M6 TT build. Along with a bunch of other dreamy cool stuff that seems above and beyond at this point. Not downplaying their ability by any means, but so far I haven't seen anything besides renderings and prototype pictures.
hhhehehe
I've heard elsewhere that the Gintani car has run with DCT, but still think it odd there are no better pics/vids/accounts of it. Given its a commercial venture for them, I doubt they'd be willing to share much with us, but who knows.
I received my DCT gear shift assembly this weekend. I was pleasantly surprised to find the three mounting holes line up with those of the SMG shifter. The base is larger on the front left corner to accommodate the parking lock, so I'll have to get center trim removed on my car to get a feel for underneath.
Thought I took a picture, but apparently not. Will post later.
Nice to see some similarities between both systems.
Confirmation from Jim Blanton of Performance Gearing this morning:
The 3.15 ring and pinion are interchangeable onto the E6x diff carrier
Discussion Starter #79 (Edited)
Here are the message exchanges for the PT_CAN. Note GWS & DME transmissions. Not a lot originating from DCT...DCT seems to be pretty self sufficient
Message description, ID#, IDhex, sending Control unit
Abstandsmeldung PDC Hinten 877 (36Dh) PDC [65]
Abstandsmeldung PDC Vorne 869 (365h) PDC [65]
Akustikmeldung PDC 454 (1C6h) PDC [65]
Anforderung Klima Hybrid 665 (299h) IHKA [128]
Anforderung Radmoment Antriebsstrang 191 (BFh) EHB3 [29], LDM [36]
Anforderung Radmoment Antriebstrang Summe FAS 349 (15Dh) EHB3 [29]
Anforderung Radmoment Antriebstrang Summe Stabilisierung 350 (15Eh) EHB3 [29]
Anforderung Radmoment Bremse 213 (D5h) LDM [36]
Anfrage Aktivierung Funktion Parken 942 (3AEh) CIC [26], CIC_MID [10]
Anzeige ACC DCC 403 (193h) EHB3 [29], LDM [36]
Anzeige Getriebedaten 466 (1D2h) EGS_EL [60], HIM [8]
Anzeige HDC 813 (32Dh) EHB3 [29]
Anzeige Hybrid-Vorteil 1005 (3EDh) HIM [8]
Anzeige Hybrid-Vorteil Reset 643 (283h) CIC [26], CIC_MID [10]
Anzeige Kombi Erweitert 711 (2C7h) DDE1 [58], DME1 [112]
Anzeige Motordaten 373 (175h) DDE1 [58], DME1_Hybrid_Gen1 [5], DME1 [112]
Anzeige Schalthinweis 755 (2F3h) DDE1 [58], DME1 [112]
Anzeige Status Hybrid 700 (2BCh) HIM [8]
Austausch EHB3 SBA 231 (E7h) EHB3 [29]
Austausch SBA EHB3 232 (E8h) SBA [8]
Außentemperatur/Relativzeit 784 (310h) Kombi [140]
Bedienung Fahrwerk 920 (398h) CIC [26], CIC_MID [10]
Bedienung Getriebewahlschalter 2 408 (198h) GWS [32]
Bedienung Lenkstockstaster 494 (1EEh) FRMFA [62]
Bedienung Lenksäulenverstellung 490 (1EAh) IHKA [128]
Bedienung Sitzmemory BF 498 (1F2h) SM_BF [93]
Bedienung Sitzverstellung BF 210 (D2h) SM_BF [93]
Bedienung Sitzverstellung FA 218 (DAh) SM_FA [96]
Bedienung Sonderfunktion 552 (228h) CIC [26], CIC_MID [10]
Bedienung Taster Audio/Telefon 470 (1D6h) SZL_LWS [70]
Bedienung Taster DSC 790 (316h) IHKA [128]
Bedienung Taster Einparkhilfen 791 (317h) IHKA [128]
Bedienung Taster HDC 794 (31Ah) IHKA [128]
Bedienung Taster M-Drive 473 (1D9h) SZL_LWS [70]
Bedienung Taster Sport 653 (28Dh) GWS [32]
Bedienung Taster Vertikaldynamik 652 (28Ch) GWS [32]
Bedienung Tempomat/ACC 404 (194h) SZL_LWS [70]
Bedienung Wischertaster 678 (2A6h) SZL_LWS [70]
Beschleunigungsdaten 691 (2B3h) EHB3 [29]
Blinken 502 (1F6h) FRMFA [62]
Codierung Powermanagement 917 (395h) CAS [86]
Daten Antriebsstrang 3 1020 (3FCh) DME1_Hybrid_Gen1 [5]
Dienste 1408 (580h)
1535 (5FFh) Diverse Sender
Dimmung 514 (202h) FRMFA [62]
Drehmoment 1 PT-CAN 168 (A8h) DDE1 [58], DME1_Hybrid_Gen1 [5], DME1 [112]
Drehmoment 2 169 (A9h) DDE1 [58], DME1_Hybrid_Gen1 [5], DME1 [112]
Drehmoment 3 PT-CAN 170 (AAh) DDE1 [58], DME1_Hybrid_Gen1 [5], DME1 [112]
Drehmomentanforderung DSC 182 (B6h) EHB3 [29]
Drehmomentanforderung EGS 181 (B5h) EGS_EL [60]
Drehmomentanforderung Lenkung 177 (B1h) EHB3 [29]
Elektronischer Motorölmessstab 897 (381h) DDE1 [58], DME1_Hybrid_Gen1 [5], DME1 [112]
Elektronischer Motorölmessstab M 898 (382h) DDE1 [58], DME1 [112]
Erkennung Verkehrszeichen 647 (287h) KAFAS [15]
Fahreranzeige Drehzahlbereich 818 (332h) DDE1 [58], DME1_Hybrid_Gen1 [5], DME1 [112]
Fahrgestellnummer 896 (380h) CAS [86]
Fahrzeugneigung 774 (306h) FRMFA [62]
Fahrzeugtyp 904 (388h) CAS [86]
Fahrzeugzustand 928 (3A0h) JBBF [55]
Freigabe Klimakompressor Elektrisch 668 (29Ch) HIM [8]
Freigabe Kühlung Hochvoltspeicher 891 (37Bh) IHKA [128]
Geschwindigkeit PT-CAN 416 (1A0h) EHB3 [29]
Getriebedaten 186 (BAh) EGS_EL [60], HIM [8]
Getriebedaten 2 418 (1A2h) EGS_EL [60]
Getriebedaten 4 266 (10Ah) EGS_EL [60]
Höhenstände Luftfeder 530 (212h) EHC [57]
Kilometerstand/Reichweite 816 (330h) Kombi [140]
Klemmenstatus 304 (130h) CAS [86]
Konfiguration M-Drive 970 (3CAh) CIC [26], CIC_MID [10]
Lampenzustand 538 (21Ah) FRMFA [62]
LCD-Leuchtdichte 704 (2C0h) Kombi [140]
Lenkradwinkel Oben PT-CAN 200 (C8h) SZL_LWS [70]
Lenkradwinkel PT-CAN 196 (C4h) EHB3 [29]
Löschen Diagnose Information 781 (30Dh) HIM [8]
Marker 2 1002 (3EAh) Diagnosetool_K_CAN_System [53]
Marker 3 1003 (3EBh) Diagnosetool_PT_CAN [41]
Memoryverstellung 523 (20Bh) SM_FA [96]
Motordaten 464 (1D0h) DDE1 [58], DME1_Hybrid_Gen1 [5], DME1 [112]
Motordaten 2 899 (383h) DDE1 [58], DME1_Hybrid_Gen1 [5], DME1 [112]
Nachlaufzeit Klemme 30 fehlergesteuert 940 (3ACh) JBBF [55]
Nachlaufzeit Stromversorgung 958 (3BEh) CAS [86]
Nachtankmenge 785 (311h) Kombi [140]
Navigation GPS 1 842 (34Ah) CIC [26], CIC_MID [10]
Navigation GPS 2 844 (34Ch) CIC [26], CIC_MID [10]
Navigation System Information 846 (34Eh) CIC [26], CIC_MID [10]
Navigationsgraph 632 (278h) CIC [26], CIC_MID [10]
Navigationsgraph Fahrspur 1015 (3F7h) CIC [26], CIC_MID [10]
Navigationsgraph Geschwindigkeit 972 (3CCh) CIC [26], CIC_MID [10]
Navigationsgraph Karten Daten 1068 (42Ch) CIC [26], CIC_MID [10]
Netzwerkmanagement PT-CAN 1152 (480h)
1279 (4FFh) Diverse Sender
OBD Daten Motor 1007 (3EFh) DDE1 [58], DME1_Hybrid_Gen1 [5], DME1 [112]
PIA Daten Anfrage 1026 (402h) CIC [26], CIC_MID [10]
PIA Daten Setzen 1027 (403h) CIC [26], CIC_MID [10]
PIA Konfiguration 1030 (406h) CIC [26], CIC_MID [10]
PIA Transaktion 1032 (408h) CIC [26], CIC_MID [10]
Position Fensterheber BFT 952 (3B8h) FRMFA [62]
Position Fensterheber BFTH 953 (3B9h) JBBF [55]
Position SHD 954 (3BAh) FZD [48]
Powermanagement Batteriespannung 948 (3B4h) DDE1 [58], DME1_Hybrid_Gen1 [5], DME1 [112]
Powermanagement Verbrauchersteuerung 947 (3B3h) DDE1 [58], DME1_Hybrid_Gen1 [5], DME1 [112]
Programmierung Stufentempomat 817 (331h) CIC [26], CIC_MID [10]
Raddrücke PT-CAN 690 (2B2h) EHB3 [29]
Radgeschwindigkeit PT-CAN 206 (CEh) EHB3 [29]
Radmoment Antrieb 1 143 (8Fh) DME1_Hybrid_Gen1 [5]
Radmoment Antrieb 2 324 (144h) DME1_Hybrid_Gen1 [5]
Radmoment Antrieb 3 325 (145h) DME1_Hybrid_Gen1 [5]
Radmoment Antrieb 4 220 (DCh) DME1_Hybrid_Gen1 [5]
Radmoment Antrieb 5 221 (DDh) DME1_Hybrid_Gen1 [5]
Radmoment Antrieb 6 255 (FFh) DME1_Hybrid_Gen1 [5]
Radmoment Antriebsstrang 1 180 (B4h) DDE1 [58], DME1 [112]
Radmoment Antriebsstrang 2 172 (ACh) DDE1 [58], DME1 [112]
Radmoment Bremse 225 (E1h) EHB3 [29]
Radtoleranzabgleich 884 (374h) EHB3 [29]
Regelgeschwindigkeit Stufentempomat 512 (200h) DDE1 [58], DME1_Hybrid_Gen1 [5], DME1 [112]
Regensensor-Wischergeschwindigkeit 550 (226h) FZD [48]
Rohdaten Längsbeschleunigung 419 (1A3h) DME1 [112]
Sitzbelegung Gurtkontakte 762 (2FAh) ACSM [36]
Soll Frequenzoffset Lenkrad Warnung Fahrspurverlassen 1049 (419h) KAFAS [15]
Soll Vibration Lenkrad Warnung Fahrspurverlassen 837 (345h) KAFAS [15]
Sollmomentanforderung 187 (BBh) EHB3 [29]
Startdrehzahl 910 (38Eh) DDE1 [58], DME1_Hybrid_Gen1 [5], DME1 [112]
Status AFS 508 (1FCh) AFS [63], ICM_QL [30]
Status Anforderung Klima Hybrid 666 (29Ah) HIM [8]
Status Anhänger 740 (2E4h) AHM [63]
Status ARS-Modul 428 (1ACh) ARS_Modul [51]
Status ASA 751 (2EFh) ASA [24]
Status Batterie 907 (38Bh) DDE1 [58], DME1_Hybrid_Gen1 [5], DME1 [112]
Status BFS 554 (22Ah) SM_BF [93], JBBF [55]
Status Druck Kältekreislauf 722 (2D2h) JBBF [55]
Status DSC PT-CAN 414 (19Eh) EHB3 [29]
Status Dämpferprogramm 806 (326h) VDM [17]
Status Elektrische Kraftstoffpumpe 821 (335h) EKP [51]
Status EMF PT-CAN 513 (201h) EMF [69]
Status EPS 507 (1FBh) EPS [55], SVT [3]
Status Fahrererkennung 753 (2F1h) ACSM [36]
Status Fahrlicht 788 (314h) FZD [48]
Status Fernlicht Assistent 874 (36Ah) FRMFA [62]
Status Funkschlüssel 570 (23Ah) CAS [86]
Status Funktion PDC 887 (377h) PDC [65]
Status Gang Rückwärts 944 (3B0h) FRMFA [62]
Status Hochvoltbatterie 695 (2B7h) HIM [8]
Status Hochvoltbatterie-Kühlung 745 (2E9h) HIM [8]
Status Hochvoltspeicher 1 506 (1FAh) HIM [8]
Status Klima Front 578 (242h) IHKA [128]
Status Klima Interne Regelinfo 814 (32Eh) IHKA [128]
Status Klimakompressor Elektrisch 667 (29Bh) EKK [8]
Status Kombi 436 (1B4h) Kombi [140]
Status Koordination Vibration Lenkrad 839 (347h) FRMFA [62]
Status Kraftstoffregelung DME 823 (337h) DDE1 [58], DME1_Hybrid_Gen1 [5], DME1 [112]
Status Leckdiagnose Drucktank 743 (2E7h) TFE [10]
Status M-Drive 921 (399h) DME1 [112]
Status MMI Funktion PDC 906 (38Ah) CIC [26], CIC_MID [10]
Status Motorsteuerung CKM 937 (3A9h) DME1 [112]
Status MSA 776 (308h) DDE1 [58], DME1_Hybrid_Gen1 [5], DME1 [112]
Status QSG 384 (180h) ICM_QL [30]
Status Qualifier Rear-View 890 (37Ah) TRSVC [16]
Status Qualifier Top-View 889 (379h) TRSVC [16]
Status Reifendruck 796 (31Ch) RDC [61]
Status Reifenpannenanzeige 797 (31Dh) EHB3 [29]
Status SBA 803 (323h) SBA [8]
Status Sollmomentumsetzung 188 (BCh) VGSG [43]
Status Spurverlassenswarnsystem 807 (327h) KAFAS [15]
Status System Parken 943 (3AFh) PDC [65]
Status Türsensoren Abgesichert BN2000 481 (1E1h) FRMFA [62]
Status Ventil Hochvoltbatterie-Kühlung 905 (389h) HIM [8]
Status Verbraucherabschaltung 957 (3BDh) FRMFA [62]
Status Verschleiß Lamelle 886 (376h) VGSG [43]
Status Wasserventil 949 (3B5h) JBBF [55]
Status Zusatzwasserpumpe 719 (2CFh) JBBF [55]
Stellanforderung EMF 423 (1A7h) EHB3 [29]
Steuerung Anzeige Shiftlights 518 (206h) DME1 [112]
Steuerung Crashabschaltung EKP 309 (135h) ACSM [36]
Steuerung Fernlicht-Assistent 658 (292h) FLA [37], KAFAS [15]
Steuerung Hupe DWA 694 (2B6h) FZD [48]
Steuerung Klimakompressor Elektrisch 669 (29Dh) IHKA [128]
Steuerung LED Funktion Parken 927 (39Fh) PDC [65]
Steuerung Licht 758 (2F6h) FRMFA [62]
Steuerung/Plausibilitätsprüfung Leckdiagnose Drucktank 1034 (40Ah) DME1_Hybrid_Gen1 [5]
Synchronisation Navigationsgraph 634 (27Ah) CIC [26], CIC_MID [10]
Uhrzeit/Datum 760 (2F8h) Kombi [140]
Wegstrecke 422 (1A6h) EHB3 [29]
Wischerstatus 594 (252h) JBBF [55]
Wärmestrom Motor 438 (1B6h) DDE1 [58], DME1_Hybrid_Gen1 [5], DME1 [112]
Wärmestrom/Lastmoment Klima 437 (1B5h) IHKA [128]
ZV und Klappenzustand 764 (2FCh) CAS [86]
Übereinstimmung Navigationsgraph 840 (348h) CIC [26], CIC_MID [10]
About this Discussion
64 Participants
terraphantm
BMW M5 Forum and M6 Forums
Full Forum Listing
