RTFMI was wondering if anyone has knowledge about launch control with SMG, if you could share your experience. Any help is appreciated :1zhelp:
http://www.m5board.com/vbulletin/showthread.php?t=89020Any help is appreciated :1zhelp:
This has been discused so many times since 2005, bottom line: there is no Launch Control on US modelsI was wondering if anyone has knowledge about launch control with SMG, if you could share your experience. Any help is appreciated :1zhelp:
That is not correct. U.S. models have a "crippled" version of launch control. it operates the same way, but at lower RPMs. And the car does not have run flats!This has been discused so many times since 2005, bottom line: there is no Launch Control on US models
:confused3
:confused3
Haha, wow. If you're going to imply someone to search at least know what you're saying first so that misinformation doesn't get distributed.This has been discused so many times since 2005, bottom line: there is no Launch Control on US models
:confused3
dave and andrewsherman - yes, I read it all......
BTW, this has been discussed before, so be sure to use the search function in the future....
This subject has been beaten to death - owners were talking about starting a class action; Check late 2005/early 2006 postings about the lack of launch Control on US M5.
The simple fact that car does not upshift (a), and revs at much lower RPM (ROW M5s have adjustable RPMs for Launch Control) to me is not the launch control. To burn some tire it's ok, or you could use emergency takeoff instead.
:thumbsup:
The raisson d'etre of launch control is to provide an optimized launch, i.e., one that is faster than simply pressing/modulating the throttle. If it fails at this core function regardless of what it is called and how superficially similar it is to a real system that does this, then it is still not launch control in any meaningful sense. The simple fact is that following the ROW launch control procedure on a US car results in a launch that is slower than simply pressing the throttle. As a reductio ad absurdum, had BMW labelled the seat heater button "launch control," the car would still not have launch control in any meaningful sense because it fails to perform its core function. In the case of the US M5, the terms "crippled launch control" and "no launch control" are basically synonymous and interchangable.That fact that it is not a good launch control and not the same launch control as the ROW, does not change the fact that there is launch control. It uses the same procedure as the system in ROW, it just does not have all the features, hence having earned the name "crippled launch control".
Thank you for a concise summary. Looks like some folks never read posts on LC Class Action and should use the "search function" first, before jumping to the conclusion.The raisson d'etre of launch control is to provide an optimized launch, i.e., one that is faster than simply pressing/modulating the throttle. If it fails at this core function regardless of what it is called and how superficially similar it is to a real system that does this, then it is still not launch control in any meaningful sense. The simple fact is that following the ROW launch control procedure on a US car results in a launch that is slower than simply pressing the throttle. As a reductio ad absurdum, had BMW labelled the seat heater button "launch control," the car would still not have launch control in any meaningful sense because it fails to perform its core function. In the case of the US M5, the terms "crippled launch control" and "no launch control" are basically synonymous and interchangable.
Glock 32,Just so you know, There is no mention in my 2008 manual about launch control.
At a light I put it into S6 and held the stick forward and rev'd the car slightly and the car free rev'd and didn't roll forward! This wasn't the place or the weather to test this so I just let back off the gas and then let the stick back and drove off as normal. There was something going on which got my hopes up.
Weather has been lousy so I wanted to see if it would rev a little higher the second time or above 2,000 (then I planned to not launch again) I tried this and it sounded like it was being limited immediately when I pushed further on the gas (kind of sputtered). I understand that you are supposed to floor it to the point where you engage the kickdown button below the throttle, so maybe that was why as I was just reving it up a little.
Now as a result of this thread I have to ask...
What is "you could use emergency takeoff instead"???
This led me to think they should have just made it so when you are in first you can push forward and engage the clutch and that when you bring the stick back the clutch would disengage or let-out at whatever RPM you rev'd up to. You would have this control in a manual transmission and same worry for abuse on the clutch, etc...
Well then, by your logic launch control simply does not exist anywhere for the M5 as almost everybody unilaterally agress that it is not the optimum method of "launching" the car -- even in its purer ROW form.The raisson d'etre of launch control is to provide an optimized launch, i.e., one that is faster than simply pressing/modulating the throttle. If it fails at this core function regardless of what it is called and how superficially similar it is to a real system that does this, then it is still not launch control in any meaningful sense. The simple fact is that following the ROW launch control procedure on a US car results in a launch that is slower than simply pressing the throttle. As a reductio ad absurdum, had BMW labelled the seat heater button "launch control," the car would still not have launch control in any meaningful sense because it fails to perform its core function. In the case of the US M5, the terms "crippled launch control" and "no launch control" are basically synonymous and interchangable.
ouich
