1 - 6 of 6 Posts
I got a new garage this year which has some openings, so temperature in it is almost the same as outside. As winter came, I noticed this knocking sound when I start the car when it is cold. The sound is clearly audible inside the car but I almost cannot distinguish it outside with the hood open. If I rev the engine a bit (like +200-300 rpm) it disappears. It also completely disappears after only 30-60 seconds, i.e. the car is a bit warm but far from normal operating temperature.
Following this thread I checked the power steering fluid level and it was slightly low, so I filled it in. There was no change, the sound remains.
I tried to capture the sound, including how it disappears when revving the engine in the following video.
UPDATE: The sound is clearly audible from the outside, front left underneath the car as seen on this video:
Any ideas of what this might be and how to handle it?
To me it sounds more like a bad bearing rather than something in the engine knocking. Maybe one of the belt rollers? Waterpump? Throwout bearing? Does pressing a clutch affect it? Maybe try starting it without belts, see if sound remains
That is a rattle from something outside the engine. If you count the clicks in so many seconds, in other words how fast it happens. At idle your car makes ~ 10 revs per second, that click is about every 1/2 second. There are so many things that get loose in time it is hard to say. Oil filter mounts and the same for PS reservoir, plus a thousand other things. All I can say is that does not sound serious.
My opinion…..
Sounds like a bad Vanos to me!
It could be alot more to it
1 - 6 of 6 Posts
