1 - 1 of 1 Posts
I have tried search and while there are threads on the topic, none really answer my question. Excuse me if I re-plowing fields.....
I am trying to install an aftermarket/keyless entry system into my Oct 1992 build M5 Touring. Not sure if it matters, but the car has EDC.
The system I bought was pre-wired for e34 and can be found here.
I plugged in the wiring harness to a receptacle under the rear seat, driver's side (left). But it does not work; while there is power to some of the wire, not all that should have power (like the main power) and I'm wondering if I have the correct receptacle or if a fuse or relay are not working.
Any help appreciated--is it plugged into the right receptacle? If not, where would it be on an EDC-equipped euro model like mine? If it is the right receptacle, which fuses and relays would control the power? Any other thoughts/suggestions?
Here ares some pics, it is next to the green fuses.
Vehicle Automotive tire Automotive lighting Circuit component Hood
Circuit component Electrical wiring Electronic engineering Cable Electrical supply
1 - 1 of 1 Posts
