1 - 3 of 3 Posts
I believe the hack is just to rig a signal repeater where the chain is YOU to Signal Sniffer to Signal Emitter to Car. The sniffer component has to be close to you (ie same distance that your car normally would be when the fob can activate it). Normally if you're careful of your surroundings it should be fine but yeah, you're vulnerable in crowded areas.
1 - 3 of 3 Posts
