WOW that's gonna be LOUD. I'll listen for you up in Carlsbad.. :1: :1: :1:
Chuckc said:WOW that's gonna be LOUD. I'll listen for you up in Carlsbad.. :1: :1: :1:
SC'dKellenersM5 said:As one who not only did the install on my own car for the xpipe/kelleners setup and also helped Josh with his, its really not that difficult. Measuring is the issue and having something that will cut through the pipes...that was our largest set back was that the sawzaw that we were using just had the blades chewed to crap in about half a pass through any pipe. And since you need to cut 4 pipes, it takes about 8 blades...
If you use a torch, make sure that you clean the spackle out of the pipes with a file just to ensure the best outside diameter fit and that the inside is as restriction free as possible.
When I was looking for M5s back in 2002 I looked at a used one and drove it through Rancho Santa Fe. That was the first time I drove an M5 and that was a great testing ground. From the coast, up Del Dios highway and back, then through the back roads. Seems like just yesterday. Since then I sold my M5 my the mention of Rancho Santa Fe brought back great memories. The build up of checking out a number of M5s and finally getting one was awesome.mmmmmmjhendershaw said:I drive through Rancho Sante Fe every day - I wouldn't be surprised if you've seen me. 01 black m5 with tubi exhaust -
cheers
Jason
Chuck, no problem with the hijack. Ya I love taking drives through Rancho Santa Fe. Its a lot of fun twisties and the roads are usually empty if you can find the right ones. I think us North County SD guys need to get together sometime, I would really like to meet some other M5 owners (as of now I have yet to meet any other owners in person)Chuckc said:When I was looking for M5s back in 2002 I looked at a used one and drove it through Rancho Santa Fe. That was the first time I drove an M5 and that was a great testing ground. From the coast, up Del Dios highway and back, then through the back roads. Seems like just yesterday. Since then I sold my M5 my the mention of Rancho Santa Fe brought back great memories. The build up of checking out a number of M5s and finally getting one was awesome.mmmmmm
Oops, sorry to highjack the thread MChap. :1: :byebye:
Rob,SC'dKellenersM5 said:The stock pipes will need to be cut to the crimp where the two pipes actually have been welded together on the OEM setup.
The xpipe wil need to be trimmed about 2" on the ends where it will connect to the kelleners exhaust.
Mark,
easy is only in the eye of the beholder. By all means it is not complicated but certainly it is not easy. There are quite a few things that you will probably want to look into if you are doing this as a DIY job.
Rob, I understand. There is a place in my area, Group 5 Motorsports, that is a well known BMW tuner shop in the San Diego Area. I have already gone over the process with them and they understand there is some cutting, etc involved.SC'dKellenersM5 said:I would suggest that you do alot of questioning of shops in your area then. While this isnt a complicated install, it does involve quite a few steps and if someone just walks into it without either working on BMW's before or taking the time to understand what the project requires, there might be complications at the end or anywhere in the process.
I have no recommendations, but would be interested to where you take it & how it goes. I may have the same thing done later this summer & would like to take the car someplace that's done this before!///M_CHAP said:Rob, I understand. There is a place in my area, Group 5 Motorsports, that is a well known BMW tuner shop in the San Diego Area. I have already gone over the process with them and they understand there is some cutting, etc involved.
However, if any of you SD guys know another place to go, I am open to suggestions.
Mark
Murph said:I have no recommendations, but would be interested to where you take it & how it goes. I may have the same thing done later this summer & would like to take the car someplace that's done this before!![]()
Depends on the suspension, my friends and I got the exhaust on in two hours and none of us had ever actually put one on before and about thirty minutes of this time was waiting for more sawsall blades while one of our friends ran to the store to get more, so maybe it takes longer if only one person is actively working on it, or maybe it takes 6 hours to place the suspension, could be wrong but coudlnt you do the suspension yourself in your driveway or garage with just a jack and simple hand tools and save some money? might be worth a try, Josh///M_CHAP said:I'm planning on taking it to Group 5 motorsports. I called today and I'm going to make an appointment tommorow.
I am getting my x-pipe, exhaust, and my KW Variant 1 coilovers all installed and they said it would take around 8 hours. From you guys that have these parts, does it take around 8 hours? Or are they trying to get some extra $$$ out of me?/
thanks for your input,
Mark
bmwusa said:Depends on the suspension, my friends and I got the exhaust on in two hours and none of us had ever actually put one on before and about thirty minutes of this time was waiting for more sawsall blades while one of our friends ran to the store to get more, so maybe it takes longer if only one person is actively working on it, or maybe it takes 6 hours to place the suspension, could be wrong but coudlnt you do the suspension yourself in your driveway or garage with just a jack and simple hand tools and save some money? might be worth a try, Josh
