1 - 10 of 10 Posts
So I was just driving along in my beast and coming up to a red light everything in the car reset about 3 times, DSC came on, battery light, CEL, etc.
Happened about 3 times real fast, though the car stayed running. Continued driving and it didn't happen again, restarted the car a few times to see if it would come up again but it never did?
Any one ever have this happen to you? I was thinking a alternator voltage issue but the alternator is brand new as well as belts and tensioner's?
Any direction is appreciated!
If the battery light came on, it could be related to the alternator or voltage regulator going out or starting to. Maybe that affected the other systems with low voltage causing the errors. I would check for stored codes, they may help.
Alternator and battery are all good! Happened again today for the first time, any other ideas?
Got an idea but waiting to see if it fails to replace it.
I would first check the battery cable. There was a recent post on one member's cable comming loose. You also said that the alternator is new... I would check that it was installed properly and ground wires are all conneced properly
I agree with above post about the altenator. How long ago was the altenator replaced? Within the last month or so? If so I would check all areas that are affected by altenator replacement. Like he said, it may be a loose connection either directly related to the installation or affected by it.
also check the postive cable connections that are under the hood, not just in the trunk with the battery
I agree with the others, definitely sounds like issue with batt/alt/cables
good luck
1 - 10 of 10 Posts
