1 - 6 of 6 Posts
Now that I've changed routes I'm finding that the car seems to judder a lot in slow moving traffic.
The day is a bit carp, 6 miles including 5 roundabouts and 3 sets of lights in 6 miles.
However the car seems to really judder going through the tunnel. Jerking forward so much I have to ride the clutch at times.
eg. Doing 20 mph but the revs drop to 700 and I can feel the car juddering. I don't want to try and slip the car into 1st whilst I am moving as that can be just as bad.
What do peope think?
Coilpacks?
At that speed in 2nd you may just not be giving it enough throttle to keep the revs up and it may be bogging down a bit.
I get a similar thing in stop-start motorway/London traffic where 1st is too high and 2nd is too low, and it's a right pain, but I either try to put slightly more throttle in, or as you've found, feather the clutch.
If you get an opportunity Ebbers , try another MAF .
Also , check the basics i.e. plugs , air leaks etc .
That said , as Tony rightly pointed out , 700rpm is extremely low revs for an S38 engine and a simple shift into 1st gear may be the solution at 20mph ......these cars aren't afraid of being driven briskly !
D
Cheers for the replies lads.
I think that's part of my problem, I've heard so many horror stories about things going wrong that I'm afraid to drive them like a proper car in case something drops off!
Althugh saying that I just don't think I have the minerals to drop a car from 2nd to 1st whilst doing 20mph. A lot of cars just don't like it.
The reason I said coilpacks was because the car has done almost 90,000 miles and I think they are all original. The MAF probably is too as I can't see a receipt for it :(
The reason I said coilpacks was because th car has done almost 90,000 miles and I thin they are all original. The MAF probably is too as I can't see a receipt for it :(
Just do a good, solid blip of the throttle with the clutch engaged and it'll slip into 1st quite easily (1st is good for an indicated 32mph).
With both of the E34 M5s I've owned, lumpy running at low revs is a characteristic of this engine.
I spent a lot of money on the first example I owned having coilpacks replaced, throttle bodies balanced, and so on - only to find it improved things only slightly - I just wasn't used to the low-rev 'lumpiness' of the S38B38.
I wouldn't drive it too far at 700rpm - with warm oil you've got fairly low oil pressure at such low engine speed......as DavidOli says - this motor thrives on revs....:hihihi:
1 - 6 of 6 Posts
