Hi guys,
I have a 1992 E34 M5 3.8. A previous owner installed an aftermarket Link Storm G4+ ECU for odd reasons. Along with this he installed Bosch 465cc injectors and a broadband lambda.
When I bought the car it used too much fuel and it felt kinda jerky. I had the car remapped and it became a different car. Much better with a normal fuel consumption. However, this didn't last and the car was kinda moody. I decided to abandon the aftermarket ECU for many different reasons and go back to stock. One of the reasons was that you need expertise to tune the car, and that I never felt comfortable with it. Also I had two people driving behind me telling me that my car smelled an awful lot of (unburned) fuel.
I'd rather don't want to make this post about whether or not to go standard ECU or standalone. The Link Storm G4+ ECU utilized only the TPS, a sensor measuring the barometric pressure and a temperature sensor. There were no sensors on the intake at all.
The ECU that was in the car while a previous owner installed the Link ECU was long gone so I had to source one used.
The last trip I drove with the aftermarket ECU the car behaved kind of normal.
So, the MAF sensor was brought brand new 3 years ago. However it was not utilized by the aftermarket ECU, but was/is mounted in the car. It has less than 10.000km. We installed the used stock ECU along with a brand new original lambda sensor that was mounted in the X of the supersprint exhaust. We also installed brand new original fuel injectors. we changed the oil and installed a new air filter. The oil smelled quite a bit of fuel. Another good reason to get rid of the aftermarket ECU. We also replaced the intake hoses on the plenum and new vacuum lines. The TPS was also replaced last summer.
This is a car that gets driven about 3-4000km each summer.
So, the problem. The car started right away with the new parts described above. However it doesn't feel too good to drive. On stable, low and medium throttle it feels quite a bit jerky, like the car holds back. It also feels kind of like towing a trailer, a bit pulsating. On full throttle it feels fine.
This behavior came as a direct result of the work we did going back to stock. However, the car has always been a bit up and down, but it actually became worse going back to stock ECU, and that wasn't what I'd hoped for.
I know a guy who has a completely rebuild engine, same car as mine. Everything in that engine is brand new. He also has the same problem now! He rebuilt his MAF and has new crank and cam sensors. He also has the same problem as me.
Is there anyone out there that can shed some lights on this issue please?
This is my car:
This is my car:
