641 - 660 of 660 Posts
Hi Jed,
The Alpine White recipient example looks very clean in the pictures ! looking to be a 'number' of such that are S62 converted around the world now :) I might have to paint mine another colour now! ;)
Is this example going to be for a customer/enthusiast? or is it going to be your own personal one?!
Will be following your excellent work and updates !
Cheers, Dennis!
Discussion Starter #642
Hi Dennis, the white wagon build is mine. No plans other than a bone stock build. Fighting the urge to do a few mods here and there but I really want to do a bone stock iteration. I'm looking forward to keeping it simple this time.
Discussion Starter #643
Meanwhile in the Unicorn's lair, working to get the Unicorn ready for its yearly outing to Bimmerfest. It's a couple of days away.
Ordered some fresh grilles. Took out the US Spec license plate holder to put on a genuine euro plate so I can pretend. I likes.
M5 JED Sent you a PM. Trying to get in touch with you regarding a M5 part.
Jay
Discussion Starter #646
Will respond shortly Jay.
Discussion Starter #647
Hi M5Jed,
Thanks for the little update and will be watching your progress :)
Surely, you'll modify some of the known S62 weak points for better reliability and performance ?
Will be cool to see what 'options' you decide to add into the car - Heritage version of the interior? two tone and if so the colour combination? a really good re-trim specialist I think I read as you already do know? also all the rest of the OEM stuff you can add/fit !
Cheers, Dennis!
I'm not really back. Notice that I still can't post on my threads that market my products.
@M5 Jed
Jed, i hope you're well.
A question about your M5 Touring project; how did you get around the GM/LCM/EWS amalgamation?
Did you use the locks and keys from the M5 in the Touring or did you use the Touring Keys and have to re-code the GM/LCM/EWS.
I'm about to start this project with a '97 540i Touring and a '00 M5.
Deepan
(I need some more posts to send pm's)
@M5 Jed
Deepan
When I've done stuff like this in the past, I manually set the VIN on the new module using PAsoft and set mileage to 0. It'll automatically update the mileage to correct without a tamper dot.
Does PAsoft need any specific hardware or can it run from a laptop with inpa and the usual obd1/2 cables?
Does anyone have @M5 Jed's contact details? Or anyone else done a V8 to V8 swap that can shed some light as to what to do?
Cheers.
Pa soft requires its own adapter. I purchased on ebay from this seller because they were US based. Can get cheaper if not in a rush
https://www.ebay.com/itm/V1-4-Diagnostic-Scan-Interface-Scanner-Programmer-For-BMW-E38-E39-E46-E53-E83-/112628672264?hash=item1a39312708
Software can be easily found online for install. Im using it on windows 7 with no issues. If need help finding the software send me a PM and I'll help
As far as S62 swap help.... if you have an M5 I suggest joining the E39 M5 owners Facebook group. Very helpful folks in there and several have posted wagon swap stuff. I think there are 3 wagon s62 swaps going on now?
I've got one of those already, so I'll try with the modules. I may download the 1.4 version of the software though.
Thanks.
I tried to join the Facebook group, but had a disagreement with the admin about the futility of sending photos of my M5. Apparently my opinion is wrong, so I'll stick to the current groups I run and am a member of, but I appreciate the heads up. Thank you.
There's about 3 being built in the UK alone right now, and I'm about to start in the next few days with a good friend.
He drove mine and got jealous, so now he's off to buy his own. 🤣🤷*♂
Thank you
NF aka Deepan
Discussion Starter #660
@M5 Jed
Deepan
Deepan,
Pardon the delayed response! I just finished a big build that’s going to Germany and I had a very tight schedule to complete the build before the car went on the boat.
To answer your questions...
I used all the M5’s body harness, ECU, cluster, EWS, keys, ignition and lock tumblers, LCM to build the wagon. The GM though is from the original 540iT.
I did not know that the e39 touring was available as far back as 97. I’ve only seen 99MY tourings. It will still work.
About this Discussion
141 Participants
M5 Jed
BMW M5 Forum and M6 Forums
Full Forum Listing
