1 - 8 of 8 Posts
Hey guys. Does anyone know how to measure engine oil level using Ista-D or any other program? I tried searching, and i found a thread describing the option and how to use it, but i could not do the same for my car, it may have been a different bmw.
Reason why i ask. I changed oil at an indy shop, not using the dealership anymore. When i went and picked up the car, the idrive was saying that the engine oil is above max.
I called the shop that did the engine oil service, they said to drive the car and that it should measure pretty soon the correct level. After 35 miles it showed the same, i found the option in ista to reset the measurement, drove it a bit, still shows above max. Could not find the option for engine oil measurement, so i called the stealership to poke around a bit, and the tech said that there is an option, but i would have to drive the car to the shop and pay 180$ for them to do it. So just wanted to see how much of engine oil is above the allowed, and if the car is safe to drive. Thank you in advance.
Just hold the BC button until it resets.
Engine oil should be at operating temp and on a level surface.
If it shows that the oil is overfilled the shop probably did not drain it correctly.
BMW has issued a technical note at some point about this
SI B11 01 06
S85 Engine Oil Level and Oil Service Information
MODEL
M5, M6
SITUATION
The BMW TIS and Owner's manual state an engine oil capacity specification of 9.3L with filter. Using this quantity during an oil service may result in overfilling. The approximate capacity, when performing an oil service, is closer to 8.8 liters following the procedure outlined below.
The S85 engine is equipped with a quasi-dry sump oil lubrication system. For this reason, the primary oil pump contains two oil pumps and is driven by a chain connected to the high pressure VANOS pump. One of the pumps is a duocentric design which pumps oil from the front oil pan area, ahead of the power steering gear, back into the main rear oil sump. When performing an oil service it is important that the oil in the front oil pan area is pumped into the rear sump before the engine oil is drained. To do this, follow the procedure outlined below.
PROCEDURE
Refer to TIS procedure RA 00 00 610 Engine Oil Service (S85) and follow all safety precautions.
Important notes!
• Check for overfilling, using the BC function as described below, before draining the engine oil. If the engine is overfilled, additional oil may remain in the front area of the oil pan even after performing the extended idle, as described below. If the engine is found to be overfilled, correct by draining the oil filter housing (approx. 0.4 liters), reinstall housing drain plug, and recheck the oil level. Repeat this procedure, as needed, to obtain a correct oil level before beginning the oil service procedure.
The S85 displays the amount of oil above or below the MIN mark. For example: a reading of 1.0 would indicate the maximum allowed oil level which is 1 liter above the minimum. An oil level maintained between the MIN and MAX marks is recommended.
Refer to the owner's manual, the ST505 M5 E60 Complete Vehicle training manual, or attachment: S85_Oil_Level.PDF, for a list of possible displays.
1. The engine must be run at idle, while at operating temperature (engine oil temperature greater than 70°C), for one minute with the vehicle stationary in a level workstall. This procedure will pump the majority of the oil from the front oil pan area to the rear sump immediately prior to draining.
2. Follow the repair instructions for draining engine oil and replacing the filter element and sealing rings.
3. Re-fill the engine oil with 8 liters of Castrol TWS Motorsport SAE 10W-60 Synthetic Oil.
4. Start the engine and run until full engine operating temperature is reached (engine oil temperature greater than 70°C). An oil level reading in the instrument display, using the on-board computer button can now be performed. To perform a "Quick Measurement" oil level check using the BC function, press and hold the BC button for greater than two seconds to begin the test.
5. Once a level reading is displayed, correct by adding the calculated the top off quantity, if needed, as described in the repair instructions. Never overfill above the MAX
Additional Information!
Any top off of 0.5 liters or less will not be indicated as a change in the oil level display until the vehicle is driven for an extended time.
The "Long - Term Measurement" is the preferred method to achieve the most accurate oil level reading. This analysis of the oil level signal, by the DME, can take some time to complete depending on various engine operating conditions while driving.
Important!
At the1200 mile running-in inspection, the CBS reset must only be performed using the GT1/DISplus. This ensures that the DME changes the oil level calculation algorithm used for the break-in oil to that needed for the Castrol TWS Motorsport SAE 10W-60 Synthetic Oil. Performing this initial CBS reset through the instrument cluster will not make this algorithm change and fluctuations in the displayed oil level may result. This status is displayed in the Diagnosis test module path for the Oil Condition Sensor:
Function Selection / Complete Vehicle / Drive / Motor Electronics / Oil Supply / Oil Condition Sensor.
It is also recommended to use this reset procedure for all subsequent Condition Based Oil Services as well.
Reactions: dbenkert
With all of my cars, bmw or other, I always fill a half qt shy to account for oil left in the engine and measure from there. Seldom do I ever have to add more to reach max reading.
Great contribution with the TIS, using the drain in the filter housing to bleed off an overfill is good to have in the back pocket.
Also if you have the two drain plugs it’s easier to drain out the old oil.
Thank you all for your replies. Definitely will do my own oil changes from now on. My initial question was if there was an option in Ista-D to check oil level. So i searched and I actually found one, how accurate is it i don't know. I may need more posts to post picture.
To access the oil level measurement you go
Vehicle management > Troubleshooting > Function structure > Power train > ABL Oil Condition Sensor > Display and basically follow from there. My engine was definitely overfilled 0.7 to be exact, hopefully i didn't make too much of a damage to it.
Cheers.
Inpa gives you the reading in mm. The oil sensor reads how high the oil is, thus a reading in mm. This is where ista translates that into volume via a built-in table.
It's under engine, read status, analog 2 then page down going from memory.
1 - 8 of 8 Posts
