1 - 6 of 6 Posts
OK, nothing new here, my M5 has the shimmy that a lot of us have experienced. At about 50MPH, I could feel the shimmy in the steering wheel and I just lived with it as I know it's a known issue. So this past weekend I put on a set of 15MM spacers, mostly for appearance. I like the look of the wheels out a little bit as opposed to stock, and I get 2 side effects that I didnt expect:
1. A little but of understeer, which is fine with me. It loosened it up just a little and I like it.
2. Here's the suprise, the shimmy is all but gone! :wroom:
I can understand the understeer, but does the shimmy going away make sense? I don't understand the physics of it all, but whatever it is it worked (for now anyway)
Anyone else experience this? :confused2
I have no experience with spacers on M5's, but have used them before on other cars with no ill effects. I don't know why the shimmy would be gone, but I'd love to see some pictures of the car with spacers. I assume you put them on the front?
billrM5 said:
nope, wheel spacers on the back. i'll post some pictures shortly
Wow 15mm's on the back! I was thinking that I might be able to get away with 5mm without any rubbing. They are pushed out pretty far as it is. I absolutely love the look of wheels with a "dish" pushed out as far as possible without going beyond the fender.
Let's see some pics!
i had the same problem. . .it would come and go at different brake speeds. eventually, i got my brake rotors replaced under cpo. happened again. was told it was my driving habits. . .too much heat, etc. by the selling dealer (open road bmw in nj --- btw, don't ever go there. sales/service are horrendous). independent dinan dealer told me i had loose control arms and worn out bushings which all contributed to the warped rotors. i'm not sure who to believe but since i replaced the rotors and bushings (had to pay for that) as well as a wheel alignment, i haven't had any shimmy.
check your rotors. they should be covered under warranty.
Super Moderator
shimmies are extremely common on bmw's. The most frequent culprit is the 'thrust arm bushings', you'll find a lot of info here using the search feature.
1 - 6 of 6 Posts
