Recently replaced my rear ball joints and integral link. The bolt (#4) backed out and messed up maybe 1/4 of the thread on the HUB itself. I used my die cut kit to clean up the outer threads and was able to screw a brand new bolt from dealer. I torqued it 77lb/ft, but should I go ahead and apply some red loctite on it? I replaced 2 (#7) and 2 (#6) at this point in time Do you think with 1/4 of the threads slightly warped would validate the reason to replace the hub?
I'm gonna go ahead and change out the upper control arms(x4) in the rear with the car jacked up. ball joints on those control arms probably suffered some stress as the wheel went up into the well and forward towards the engine. With that.. my whole suspension will be new, except subframe bushings and diff bushings.
