1 - 13 of 13 Posts
Hi M5Board!
Today I am listing for sale my beloved E39 M5. I believe I am the 4th owner according to Carfax. The car was a corporate business car for 3 years and then transferred to 2 other owners. I purchased the car a little over a year ago, and have put lots of work into it since first purchasing it. This car also was equipped with the Sunshade option so there are sunshade for each rear door, but because of the custom stereo system, the rear sunshade had to be removed. Some of the features I want to note to someone who are not familiar with the E39 M5, are Automatic Climate Control, Heated Seats, 3 Position Memory Driver Seat, Telescoping Wheel, Suede Headliner, and Xenon Headlights.
The car runs flawlessly and is a joy to drive. By far the best handling and performing M5 I have ever driven. The reason for me selling it is because I am building a Porsche track car and I need to make room.
There have been lots of modifications made to this car so I will give a breakdown to help describe the car best.
PERFORMANCE:
Dinan Carbon Fiber Intakes
Custom Short Velocity Stacks
Custom Jailbreak Tune It has been tuned for both Alpha-N Mafless and for use with Maf sensors along with lots of other features. I can also provide Dyno Run information for the custom tune if requested.
SuperSprint SS Cat-Delete Pipes
Rouge Resonated X-Pipe
BillyBoat Rear Section Mufflers
AC Schnitzer Short Shift Kit
SUSPENSION / DRIVETRAIN:
KW Suspensions V2 Adjustable Coilovers Less then 8k miles on them since install.
BBS CH-R Staggered Wheels wrapped in V12 EVO tyres in front and Goodyear run flats in the rear. Goodyears are brand new mounted and balanced one week ago.
Dinan Rear Sway Bar
ECS Tuning 15mm spacers
Stoptech Vented Rotors Front and Rear with Carbon Pads
Lemforder Front and Rear Complete Suspension Overhaul with upgraded bushings which included:
2x Control Arm and Ball Joint Assembly
1x Control Arm and Ball Joint Assembly
2x Stabilizer Bar Link
2x Tie Rod End
1x Steering Center Link
1x Steering Idler Arm
2x Integral Link
2x Guide Rod
2x Suspension Control Arm and Ball Joint Assembly
2x Ball Joint
EXTERIOR:
VIS Carbon Fiber Hood
Black Kidney Grills
2001 Xenon Headlights with 35W Ballasts and Phillips High Output Bulbs
European Clear headlight lens
ICE 6000K Angel Eyes
Slimmbones XL Foglight Covers
Gloss Black Roof
LED Smoke Hella Taillights
AC Schnitzer 3 Piece Rear Diffuser
Custom Badging in German Flag Colors
LED License Plate Lights
INTERIOR:
Custom Rockford Fosgate Sound System In Full Inclosure. The entire trunk has been lined with black suede including the illuminated sub enclosure. The front door speakers are Rockford Fosgate and the rear are JBL. The subs are Rockford Fosgate P2 Punch 12in in a suede and clear glass box complete with lighting. The 2 amps are both Rockford Fosgate constant power amps in fiberglass enclosures.
Dynavin 7in touchscreen GPS Headunit. Comes with all connections for iPhone, Aux, and USB
Custom Carbon Fiber Dipped Trim
European Tilt and Sliding Armrest
Mfest "Plush" Floor Mats
AC Schnitzer Pedal Set
AC Schnitzer Gear Shift
AC Schnitzer E-Brake Handle
Suede E-Brake and Shift Boot with Red Stitching
Red Leather Lower Steering Wheel
LED Interior Lighting
Front Cup Holder Delete Plate (No drinking allowed :)
Also the car is wired with a Viper Remote Alarm System. It is factory wired so the you can not tell it is an aftermarket alarm. Even the normal red alarm light underneath the rear view mirror acts as it should. It has a very loud alarm and offers valet mode as well as remote access.
As well as all of these upgrades I have done a lot of maintenance to the car as well all of which I have receipts for if requested.
The list of maintenance includes:
4 CPS Sensors
O2 Sensors
Crankshaft Position Sensor
Mafs (by previous owner before purchase)
Valve Cover Gaskets
Water Pump and Belts
Thermostat with O-rings
Radiator and Hoses (no receipt of for radiator but have date for proof)
Guibo or Flex Disc
Clutch (by previous owner before purchase)
Full Oil Separator System
All Rubber Hoses
Vanos Bolts and Washers
Headlight Adjusters
Driveshaft Replaced
Differential Replaced
Exhaust Gaskets and Hardware
Cabin Air Filters
Sparkplugs
Fuel Filter
Secondary Fuel Pump
Dash Pixel Fix. The entire dash was sent to Pixel Fix to have all the lights and pixel strips replaced. All of the gauges are super bright like new as well as the Pixels.
The car also runs only BMW factory coolant, Pentosin 5W30 or 5W60 Engine Oil, Royal Purple Diff Oil, and original transmission oil.
I have a full set of original M5 rims with tires as spares. I can include these instead of the BBS wheels for a discount or include them for an additional fee. I also have a second diff for a core that I was going to use for a Dinan Diff, as well as the original catalytic converters. I have a few other random parts that can be included too.
Now the cons, there are a few small issues with the car that I want to make sure the buyer is aware of.
The paint is not perfect. There are a few nicks here and there around the car. I have never much cared about them but I know to many people the paint is very important.
The drivers side seat has a tear in the leather as shown. I have tried to find a place that would recover the original seat but to no avail. Next best option I see would be to buy another seat but I haven't cared enough to pursue that option extensively.
The sunroof came off of of the track some time ago. Motor still works and the sunroof can go up and down just not back and forwards. It can be fixed but the headliner has to be removed to get to it and I have not wanted to do that. If you want the car but need the sunroof to work I can get it fixed free of charge.
This car is truly well maintained and taken car of, and it really pains me to let it go. I am asking $22,000 but open to offers.
If you have any questions or concerns about the car please feel free to message me or and I would love to answer your questions and tell you more about the car.
Thank you for your time
Blake (407)-844-6975
^Hydrographic
Exactly! It has been "dipped" in a super thin layer while in water. It feels very silky and looks amazing. Much much better then wrapped.
Thanks!
Very nicely modded M5. Although not what I am looking for, I am local and would welcome your recommendation for a good indy shop here in the Orlando area.
Also, I would recommend that you have the moonroof fixed anyways as you offered to do so at no additional cost to the new owner.
GLWS.
1 - 13 of 13 Posts
