1. There are three connections to the ignition coil. Are the two close to each other both grounds? My connections are cut and half missing so I need to make sure that neither give/get input from through the X20.
2. I am using the s14's 265/5 tranny which uses a flywheel sensor. Does anyone know if the 280 tranny does? I cannot find that pin on the X20 and see no way to hook up the s14's into the S38's wiring harness.
Thanks!
Thanks!
