1 - 9 of 9 Posts
Anyobe else's HUD not have NAV directions? YES, I checked in the HUD settings in the iDrive and its checked and greyed out; I couldnt even disable it if I wanted too I guess lol.
I know you can code turn signals in, but seeing if there is a corky idrive fix or whats up w/ this lack of NAV as I've seen some people have it automatically. Im CIC 2008, both options were factory installed.
Mine shows up. But no settings to make any changes in my I drive for it. I will be getting some coding dien Sunday from a friend I can ask him questions if you have any he's a nerd
Sent from my SM-G925K using Tapatalk
Is your "M View" box checked below the "Navigation" check box? If so, you will not be able to select navigation until "M View" is unchecked.
What Fast said. Can't have M View and the directions pop up at the same time. If you see the tach on the heads up, you're in M-View.
AH. Thank you sir's. I read that in a search and misread it at the time and thought NAV would not show up while in M MODE.
Appreciate it. The tach bar is useless anyway.
Hello
Did you ever figure out why you didnt have the settings in you I drive ? I have a car with the same issue ?
1 - 9 of 9 Posts
