1 - 8 of 8 Posts
M6 6MT Yas Marina GT3 Touring Chalk
Hi all,
Thinking of picking up a set of used HREs to fit to my M6. Considering the set I'm looking at were not built for the E63, I'm a little concerned about the offset. My question is what is the maximum offset I can run on the rear with a 20x11 rim? Car sits stock right now, no spacers or springs, but I plan to buy H&R springs and whatever spacers necessary to make these work.
I have 20x10.5 ET28 and lowered on H&R springs.
The wheel is F13 fitment but it fit with plenty of room on both inner and outer clearances.
At ET28 it did sit further inside and used 12.5mm spacers for a flushed stance.
After this it the tires started rubbing extremely bad to a point I thought I was going to bend my quarter panels. So I rolled them and all is good now.
I am running 295/30/20 Pzero.
And to be clear, it fit with plenty of clearance before adding spacers?
The wheels I'm looking at would have approximately the same inner clearance with 5mm spacers all around.
Hi all,
How about DPE's that looks like this and they will 100% have perfect fitment as they are off my 08 e63 m6 coupe. Willing to work out a deal if youre interested.
Hi all,
Discussion Starter · #8 ·
1 - 8 of 8 Posts
