HP calc formula per R&T
961 5
Dyno-time sellers beware. In the April R&T is a simple formula for calculating horsepower from 1/4 mile trap speed and vehicle weight.
it is: HP=(mph/234) cubed, times weight.
I have seen reported M5 trap speeds of 117 mph.
117/234 cubed, times 4000 equals...
drum roll......
500.
1 - 6 of 6 Posts
it is: HP=(mph/2343) cubed, times weight.
drum roll......
500.
To confirm its (mph/234)^3 * weight?
Your first formula has a typo???
The calculation is a long known formula. I have an old slide rule some where that shows that.
Remember, you should use the 'test weight', not the curb weight of the car. For my car, best trapspeed is 116.3 mph on a lousy traction track, with a test weight of 4280 lb. That gives:
525 HP
Which is probably low given the mods I have. With a better track, I should be able to hit around 118, which would give
549 HP.:M5thumbs:
S3 Horsepower Calculation(s)
My 4250 lb (E39 M5 S3 + driver) turning 11.7 @122 mph in the 1/4 mile is making:
1. hp = weight*(speed/234)^3 (Road & Track formula)
602 HP at the crank.
2. The online calculator** at Fast Math, using a 122 mph 1/4 mile trap speed
711 HP at the crank and
602 HP at the rear wheels
3. The online calculator** at Fast Math, using an 11.7 ET
619 HP at the crank and
524 HP at the rear wheels
**Black Box
The Road & Track and Fast Math ET calculations most closely approximate the 621 HP rating of the Dinan E39 S3 motor.
Ray
My 4,810 lb (CL65 + driver) turning 11.403 @121.59 mph in the 1/4 mile is making:
675 HP at the crank.
2. The online calculator** at Fast Math, using a 121.59mph 1/4 mile trap speed
796 HP at the crank and
675 HP at the rear wheels
3. The online calculator** at Fast Math, using an 11.403 ET
641 HP at the crank and
757 HP at the rear wheels
4. Drag Times Horsepower Calculator:
Horsepower Calculator from 1/4 mile ET and Trap Speed - DragTimes.com
Flywheel HP: 658hp
1 - 6 of 6 Posts
