How to exit the GPS/NAV module
1309 3
Once GPS/NAV is turned on how do you turn it off or exit out of it? I keep getting the female voice in the background.
1 - 4 of 4 Posts
I just go back to the destination input page, then hit the menu button to go back to the main menu. Unless I'm navigating, my screen is off.
· In Memoriam
Working from memory ...
Press the right hand round button ...
Select the top menu item (Input Destination) ... (one up from where the highlight sits) ... If you select the "Instruction" menu item, and hold the button, the voice will go away, but you will still have navagation info.
Press the button again ...
Then press menu ... and, select where you want to be.
As I said, my feeble memory, but you can get the "voice" OFF.
Reactions: RUFM5
1 - 4 of 4 Posts
