As per request,how to change the bowden cable between the bonnet locks and the from lock 1 to he connector in the engine bay...
Disconnect both head lights,remove the 4 bolts(8mm socket) that hold the headlights and remove them.Do not drop the bolts in the engine bay
Open the connector on the driver side,remove the cable to the bonnet handle,pull the plastic bracket of the cable off the chassis.
Remove the clamps that hold the radiator(8mm socket)
Remove the plastic clips by pushing the center pin through(hold hand underneath to catch the pin)
Remove the bolts that connect the front cross member on the fender(10mm socket)
Remove the Phillips head bolts(one each side) next to the locks.
Remove the Torx bolts that hold the locks in place(T35 socket).
Pull up the top of the cross member a bit and remove the whole unit.
Feed the wires out of the locks and install new ones.
Found out mine are toast ordered new ones from the dealer...
Assemble in opposite order,get a beer.
