Alright guys,
Here is the deal.
My beast needs a few things repaired, some I knew when I was purchasing the car (PPI) and at least 1 that I suspect also needs doing (thanks to the Search feature).
First things first, The PPI listed:
1- Center steering link and Both Tie Rods(might as well), the symptoms are vague and wandering steering and a "play" in the steering of about .5"-1": The estimate I was given was $1400. Is that close enough, should I expect a more realistic Lower Price?
2- I was told both drive shaft seals will need to be replaced in the next 6-12 months depending on mileage. I was told there isn't a leak big enough for a drop of oil in the drive way, but the seals are starting to get moist on the outside. What would be a fair price for this repair?
3- In 1st and 2nd gear I can feel a very very slight vibration. It is extremely hard to notice and I have only felt it 2-3 times. From searching I understand that this could be the first sign of guibo going. If it does turn out to be true, should it be done in conjunction with one of the above repairs and if not, how much $?
I appreciate if you guys can share what you had to pay for the above repairs if not DIY. I am just trying to budget the repairs and if they all need to be done at the same time, I am going to need to plan ahead.
Since there are other "new" owners on the board, I am hoping it will help others as well.
Thank you all
Here is the deal.
Thank you all
