1 - 16 of 16 Posts
I'm not aware of any posts that have critiqued the M5's sound system. My friend is picking up his 540i next week and he ordered it with the premium sound system that I guess has quite a few speakers as well as a subwoofer. What does the M5's consist of component-wise. What are it's specs? I've listened to some pretty lame factory systems in high end cars and I'm hoping my '01 M5 won't have one of them when I take delivery next spring. Thanks in advance.
Doug
The M5 sound system (as I understand it) is a 14 speaker system. I've listened to a number of different trakcs to compare it to my home system (all sorts of different components, perfected to match the room), and it sounds PRETTY DAMN GOOD for a car stereo. Some people have complained about a lack of punch bass wise, but there have been times when I've had my rear view mirror shake a little from the bass (no, not often. just to test it).
I think it suffices well.
--Dan
the sound system will sound great to 99.9% of people, because most have been conditioned to favor an inaccurate, colored and boomy sound. it took much tweaking, but I got the system to sound a lot more neutral. overall its fine, but thats it.
ME
Menthusiast,
I second that!!!
Please share the tweaks!
I have owned both a 1999 and 2000 E55. In each of these vehicles, I had a truly specialized 1,450 Watt "stand alone" sound system that didn't interface with any of the OEM audio (of which I can share the component details of, if so requested).
Suffice to say, this system added 125 lbs of weight to the car, in addition to substantially reducing the payload capacity in the trunk (due to the massive subwoofer enclosure and amplifiers that resided in the rear section of the trunk).
With the M5, I've been so entertained with its "active", more involving driving nature (vs. the more "passive" ethos of the E55), that I have resisted the temptation to similarly equip it with a commensurate sound system.
The trunk volume of the M5 is noticeably smaller than that of the E55. Thus, such a system would more drastically impinge upon the payload capacity than even in the case of the E55.
Also, the balance of the M5 is so finely tuned by the Factory that I am reluctant to affect with the permanent 125 lbs "ballast" that is the sound system that I was spoiled by in my previous E55s.
Therefore, as a confirmed audiophile, I would immensely appreciate details of your tweaking mission so that I can optimize the (marginal) Factory OEM sound system.
I look forward to your thoughts.
[email protected]
I think the sound system in the M5 is lacking in definition, it leaves out sounds I could hear in my 325 with 6 MB Quart speakers with an amp and Pioneer head unit.For the non audiophile it should be great, plenty of bass and power. If you don't know what you are missing.... Personally I think the choice of the Alpine CD player is poor in design of the magazines and its location is not as acessible as the Nav CD unit, after all which will be used more frequently?
here you go:
the problem I had with the sound was that no matter what you played, the lower octaves of bass overwhelmed everything else. with these settings, Ive taken away this, but bewarned many will find these settings too "thin"
bass: all the way down
trebble: 0
fader/balance: middle
dsp eq:
room: 0
echo: 0
80hz: -5
200hz: -2
500hz: 0
the rest: 0
mE
Discussion Starter · #8 ·
Thanks for your replies to my original post. Like any other car system, the absolute best won't come from the factory. It also won't come cheap or without a lot of careful planning to avoid hacking the job as well as making it sound good. I must admit, I'm not buying the car for it's sound system. Just what I'll be satisfied with I'm unsure of, but at home I listen to Krell, Wadia Digital and Egglestonworks so I guess you could say I'm more than slightly critical when it comes to sound.
Doug
Let me offer a few more thoughts on the new M5 sound system. Like most of the other owners, I was annoyed by the general flabbiness of the bass and the excessive reflections and echoes present in the DSP presets. Having enjoyed an excellent aftermarket system in my E34 M5, I zoomed, as only the M5 can zoom, over to my audio dealer to pursue an upgrade. After dreaming of replacing all the electronics, save the head unit, I was brought to my senses by the head installer who said "no way" would he touch the M5. Apparently, he attempted such an upgrade on a similar (identical?) DSP-based system in a new 7 series vehicle, was utterly defeated, He claimed he was also out of pocket to the tune of about $400 to have it restored to normal operation by the local BMW dealer. He said the system simply shut down and locked up in just one attempt to upgrade the midrange drivers. I haven't checked any other shops, but this one does most of the high-end auto installs in my area and should have a handle on what is and isn't possible. If anyone has succeeded in upgrading the drivers or the amplifiers, please post your results to this thread. I'm all ears, as they say.
Faced with no immediate prospects for an upgrade, I went back to the DSP to see what I could do with the few available controls. I mean few, of course, in a relative sense. It's an abundance of controls compared to most OEM systems and the volume aftermarket upgrades, but for me it looked pretty bleak. My old M5 had a full bore DSP with adjustable delays and amplitudes for early and late reflections, 1/3 octave equalizers for the front speakers and subs, and 1/2 octaves for the rears and center channel, plus active, tunable crossovers for the bi-amplified speaker feeds. Obviously, the new M5 system isn't capable of the near infinite adjustability I had with the old system, but faced with no alternative, I sat down to see what could be done.
For me the biggest problem, other than the flabby and boomy bass, was the lack of a front facing stereo image. This was a major focus in the design of my E34's system. The early DSP unit (vintage 1991) created a true center channel. My installer cleverly placed, with a little help from his heat gun, a small "full-range" 3.5 inch Nakamichi driver under the vent grille located in the center of the dash. With the right time delays, the system created an authentic stereo image with voices and instruments properly placed from left to right and front to back, but always forward of the driver and front passenger positions.
My visit to my audio dealer had made me more aware of speaker placements, which were quite different from my old M5 and much more problematic. The culprits in the new M5 are the small drivers located in the rear doors. Although I'm relatively short (5'8"), my seat was far enough back that the earliest arrival was from unit in the left rear door. A taller person would probably find that speaker just a few inches from his or her left ear. The fix was relatively easy and, IMHO, cleans up the imaging, even for the DSP presets, to a remarkable degree. I simply moved the fader slider to the right between 6 and 8 clockwise steps of the knob. The further back the driver's seat position, the more clicks I recommend. Like a Dolby surround speaker, you should never perceive the rear door speakers as a distinct source. The fader tweak also had a side benefit of reducing the excessive bass boost. I suspect that the subwoofer level is affected by the fader control, but I haven't spent much time trying to measure the degree of the change. If I have some time this weekend, I'll pull out the Radio Shack SPL meter and measure the bass change using the TDK car stereo test disk.
I did not, as one of the other post suggests, turn the bass (or treble) control all the way down. There is a faint vertical mark at the mid-position of all the "tone" controls, and I set the treble, bass, and balance sliders to cover that middle position. I assume (who can stand watching that video?) that the middle setting is the flat setting for both bass and treble. If you're not familar or comfortable with DSPs, you might be tempted to adjust the response curve with these tone controls. After ten years with a DSP in my old M5, I generally avoid tone controls. Only in the rare case, where a poor cassette recording or DX AM broadcast needs a bit of a cut or a boost, do I ever touch them.
Returning to the DSP's equalizer, after adjusting the fader setting, I created a set of my own equalizer settings. For Memo 1, my version of Jazz Club, I arrived at a set of levels that more or less matches those posted earlier:
80 Hz - -5 (db's or something like that)
200 Hz - -2
500 Hz - +1
1000 Hz - +1
2000 Hz - +1
5000 Hz - +2
12000 Hz - +4
Room - +3 and Echo - +4
As far as the rising high end goes, I should first say that I have 50 year old ears. It's quite possible that a younger person would find it overly bright. My 13 year old son, however, did not think it was excessive, but we were both in the car and that does change the reflections and absorptions. Another factor to consider is the interior of the car. For my new M5 the major change from stock upholstery has been a pair of the sheepskin seat vests. They are more absorbent than the bare leather and might contribute to the greater treble lift.
I added a Memo 2, with the same low end equalizer settings as Memo 1, but with 0db settings for the 500 Hz and 1000 Hz sliders, for listening to news and talk. The Room and Echo settings are both at zero, as I find any artificial reflections or reverb distracts from pure spoken voice. I should note that high end DSPs found in home theater surround processors actually detect pure voice and dynamically reduce the reflection and echo amplitudes to keep voices sounding natural, but I have yet to encounter this capability in a car stereo.
Memo 3 is currently a trial setting for classical music. I'm not quite happy with it yet, so I won't comment about the current positions.
If you haven't experienced DSP before, it's fairly typical to want to turn the Room and Echo controls off for everything. My strong recommendation is to use them only for music. I think you'll will come to appreciate the fact that they can and do enhance the listening experience. In fact for me, turning them off makes the system sound like ordinary car stereo, not anything resembling either home stereo or a live performance. It's actually more like listening inside a giant set of headphones.
Relative to my previous DSP environment, the M5's DSP is rather simple. The Room control appears to set the time of the first reflection, with the delayed signal feeding the front speakers. If you were in a small room, sitting close to the combo in a jazz club, the early reflection would probably be the bounce off the room wall or stage wall behind the group. Since there is only one Room control, it may also adjust the late reflection off the rear wall and feed this to the side and rear speakers. It's only a conjecture, as I haven't crawled in the back to verify it. The Echo control appears to adjust the simulated room reverberation. Small, live rooms tend the have a earlier and higher amplitude echo and a longer decay given the hard walls. A movie theater has a later and lower amplitude echo with a more rapid decay due to seat and curtain absorption. Unfortunately, the new M5 sound system doesn't give you much control over the echo timing. The control seems to range from louder and longer at the top end and softer and shorter at the bottom end. Nevertheless, you can achieve something that is better than what even a mid-priced aftermarket system can deliver.
Bottom line for me is this is a system I can now live with. It's by no means as accurate, either in terms of imaging, response, or extension as my old M5's system, but it can be quite enjoyable. I picked up a copy of Linda Eder's recent CD "It's No Secret Anymore" (Atlantic 83236-2), at a charity auction last weekend, and popped it in the changer for the drive home. She's was a big surprise and so was the sound in the M5. The real comparison, however, will come this weekend when I have tickets to hear her and Michael Feinstein live at the local concert hall. If history is any guide, I'll be back to the DSP for a post-concert adjustment...
Here's to good driving and good listening!
I agree with your installer- the whole car runs through this system. I wouldnt mess w/ it.
I found the fader does not control the sub woofer and moving it too far to the front "exposes" the sub. if you find the bass still too boomy, try reducing the bass control. I agree about the rear speakers- IMHO- they did this on purpose- but I agree with you that its annoying.
ME
check with your local dealer,, momentum bmw out of houston tx sells and installs a 10 inch free air sub and 300 watt amp for around 700.00.. the set up adds depth and punch to the low end.. sounds great.. thx
200 Hz - -2
500 Hz - +1
1000 Hz - +1
2000 Hz - +1
5000 Hz - +2
12000 Hz - +4
I think the sound system sounds OK---for an OEM system. However,for an car the price of the M5 I would like a substantially better system, and, thus, I am not satisfied with it. I have been looking into various options and I am comtemplating the following: disconnecting the DSP and the OEM amp and connecting the tuner to 2 new amps, such as an Adcom or Highphonics amp. I would then have either a 10 or 12 inch Infinity Perfect sub mounted against the back of the rear seat armrest, which would be cut out, and then I would replace the interior speakers and disconnect the OEM sub. I would like to use Infinity Kappa Perfect speakers but the dealer will not know if the same will fit until he opens the door up. Otherwise I might have to use a much narrower speaker such as a Nakamichi.
Does anybody have any advice or information on upgrading the sound sytem in an M5 or any comments on the proposal described above?
Theres been a lot of talk about the M5s stereo sound performance/ quality. Here are the settings Ive come to that I think give a very nice sound. You might find different settings are more preferable to your taste. Keep in mind that on a graphic eq, 1khz represents the middle spot of the human voice and as you move to the right you get more trebble sounds, as you move to the left you get more bass sounds. The tone controls for bass and trebble affect a much wider range of sound. I found tweaking both controls provides a very nice sound thats not boomy yet has nice bass performance.
here are the settings:
TONE
Bass: -4 (from middle setting)
Trebble: +1
fader: +2 (it appears that the fader and balance have more steps and +2 on the fader lines up with +1 on trebble)
balance: +1(helps move the sound more to the center of the car but this is still not perfect)
DSP EQ
80: -7
200: -6
500: 0
1K: 0
2K: 0
5k: +2
12k: +3
room: 0
echo: 0
let me what you think or if you have suggestions for better settings.
ME
Well, if any of you are in the NorthEast (MA/CT/NY/NJ/PA/RI/VT/NH/etc) and want a stereo upgrade, go to Rich's Car Tunes in Watertown, MA (www.cartunes.com). Rich is a great guy and has already upgraded 2 M5 sound systems. These guys are expensive but have been in the business for years and they really know their stuff. They don't interfere or 'hack' the wiring harness of your car. They are able to obtain a pure signal (no processed garbage or DSP) from the headunit and can make the M5 sound even better than it does now!
-Chris
Chris,
thats very interesting- so you can have your cake and eat it too since the GPS voice will still work and all the controls will work- youre saying they know where to find the line level outs of the head unit- excellent!
ME
1 - 16 of 16 Posts
