136k. Only thing outside of routine maintenance is the thermostat, but that's routine maintenance as well...
Heb je al veel kosten gehad buiten normaal onderhoud?246.000 KMStill going strong.
@Andy; What where the results? I had mine done last week and the results are....strange.186000km, I will not mention all the things that I have had to change or the money spent but the good news is none of it was engine related. Compression test was done about 7000km ago and no problems.
Do you remember the model of the Magnaflow cat you used ? Is it a universal one or something along the line for the E39?116,000
Replaced:
1 CPS
1 Set of MAFS
Rear subframe (cracked)
Driveshaft guibo
Thrustarm bushings (need to replace again)
Stock CATS with magnaflows.
Do you have a copie of the sheet that came out of the compressor tester?
