Hidden/Secret menu showing *live* GPS speed [hidden navigation menu]
110K views 65 replies 37 participants last post by  Smokin Joe
#1 · (Edited)
[EDIT: downloadable PDF instructions with images, see attached files at the bottom of my post]
Ok so I posted screen shots of the main i-drive hidden menu in another thread and we all got excited about finally having a true live GPS speed view. As those who tried found out it was only a snapshot of the speed when the page was loaded and you had to click next or previous to get it to updategrrrrrrr
I refused to be defeated so did some searching round and have now found not one but two different ways of having a live GPS speed on show
  1. via hidden navigation menu
  2. via hidden on board display [dash] menu
I even took the liberty of testing them both and compared the GPS speed they show to that shown on my Origin B2 GPS unit and they're both 100% accurate and as expected a few km/h lower than shown on the dials or in the HUD.
Here we go...
1 - Hidden Navigation Menu
It appears that there is a hidden Navigation Menu showing very similar information to the main i-drive hidden menu but this one shows live GPS speed in km/h. To access the menu follow these steps:
  1. From the main i-drive menu select the navigation screen by press the i-drive controller right (east).
  2. Once in the navigation section make sure the top sub-menu shows navigation and not information, etc then go to the bottom section and highlight "Map Indicating Direction of Travel" but don't click on it.
  3. Press the i-drive controller to the top-right (north-east) corner and hold it there for 10 seconds and then release.
  4. Rotate the i-drive controller right (clockwise) 3 clicks.
  5. Rotate the i-drive controller left (anti-clockwise) 3 clicks.
  6. Rotate the i-drive controller right (clockwise) 1 click.
  7. Rotate the i-drive controller left (anti-clockwise) 1 click.
  8. Rotate the i-drive controller right (clockwise) 1 click.
  9. Press the i-drive controller down (towards the ground).
  10. You should now see part of the hidden navigation menu
    Just push the controller to the right (east) to highlight the top sub menu where you can chose from the following sections
    1. Position (ignore the speed in here, heading, etc)
    2. GPS (the gps speed, visible sats, )
    3. Guidance (info relating to route selection)
    4. System (blank for me)
    5. Map (blank for me)
    6. Simulation (you can pull down (south) to select between a few demo options but I can't get anything to work for love not money)
There you have it, your live GPS speed is shown on the Position page and is most definitely live!
2 - Hidden OBD Menu
There is also a hidden menu that you can access using the trip reset button on the instrument panel but it's slightly more involved and complicated to access but I've found some very interesting things in there including:
  • live GPS speed in km/h
  • current rpm digital read out
  • current rev limit rpm's.
I shall take photos and post instructions in another thread with a link from here. (update - I think I have too much time on my hands, just taken about 100 photos of this hidden menu so may take a little longer than first expected to post them all)
#39 ·
How in the world did I miss this the first time around???
On my '06 with the updated software (to v.26.02, I think), the GPS menu works perfectly. The only refinement is this -- when the GPS page comes up, the speed reads 0 (GPS status "1"). I held the iDrive knob down for about 5 seconds and the actual reading appeared (GPS status "0"). The speed is delayed a second or two, and it mostly shows the elevation, but neat anyway.
I have not had time to try the more involved OBC menu, but that's next.
#47 · (Edited)
Because I found the link in another thread where the information was relevant to what was being discussed at the time, it's a very useful tip and it deserved a bump so that more people could benefit from it.
I missed it the first time around, as I'm sure a lot of other people did. We all know that speedos can be innacurate, so I'm sure there are a lot of members out there who would like a more definite way of telling their speed when they're bouncing off the rev limiter.
Oh, and because I plan to give it a go in my M3 and perhaps post a link to the thread in the M3 forum if it works. :)
Just because a thread is old doesn't make it irrelevant!
#44 ·
No offense, but why in the world did you revive a three month old thread for that post?:dunno:
#46 ·
99 left! :D :D :D
#49 ·
excellent work scoopz.
Tried it today and it works. I have a few observations, just wondering if others are experiening the same.
First, the speed is flashing, quickly between, what is in pararenthesis, (km/h) and (m) with the speed before it. Don't know what the M stands for because it does not match even close to the speed I am going.
Second, as my speed increases, the speedometer seems to get increasingly more off. At 100 Mph The GPS was Km/h faster than the speedometer Km/h reading.
I have 20' wheels, perhaps this hinders reading.
Does anyone know if GPS remains accurate with different size wheels on car?
#50 ·
Speed is alternating with height in Meters.
GPS also works when just walking by foot (on zero inch wheels). So no, the size of anything really doesn't matter on GPS speed. It's just movement calculated of of a few satellites.
#51 ·
However, if you changed the size of your wheels without re-calibrating the speedo in the car, then it will be less accurate, so there will be a greater difference between the accurate GPS reading and the innaccurate speedo....
