I just put an HID foglight system on my car (that I sell on eBay) from www.purevisionhid.com, check them out:
My Philips purple definitely are not bright, but they look nice.amrit50 said:well i bought 6000k bulbs, they are more white w/ hint of blue. Not a perfect match, but way closer then the crap yellow.
While those lights really look cool, the real issue for me would be as asked by Adam, how do they improve their intended purpose? Given the intensity of xenon lights, these may only increase the amount of glare one looks through in foggy weather conditions.ard said:Is the light distribution pattern changed from stock?
My fogs only illuminate a few feet in front of the car (like 5-10 feet) and by the time I'd see it, I'd hit it.
Installation isn't too difficult, I recently fitted the bimian ones, from the pics, it looks pretty much an identical kit, the wiring plugs fit into your existing wire plug and then this goes into the ballast, with another output from the ballast into the new hid bulb. Mounting the ballasts within the front bumper in the corners.howler said:Could you post the installation instructions on this thread?
I agree, I did the umnitza ones. The bezel around the foglight just pulls out, but you have to pull pretty hard. And I found the best place for the ballast was on the "floor" of the front bumper. Everything is plug and play. Light distribution is good, although not sure it will be any improvement in fog.Tin said:Installation isn't too difficult, I recently fitted the bimian ones, from the pics, it looks pretty much an identical kit, the wiring plugs fit into your existing wire plug and then this goes into the ballast, with another output from the ballast into the new hid bulb. Mounting the ballasts within the front bumper in the corners.
yep, I was alittle concerned if there was a pile up of water which may come in contact with the ballast itself and possibly cause additional issues, hence i put them about 1-2inches above the curve of the bumper.gsfent said:I agree, I did the umnitza ones. The bezel around the foglight just pulls out, but you have to pull pretty hard. And I found the best place for the ballast was on the "floor" of the front bumper. Everything is plug and play. Light distribution is good, although not sure it will be any improvement in fog.
I'll second this question, apparently US models can swap out the LED's in the rings (at least it looks like it). I had thought that something to do with the euro versions could only swap out the LED's but if that's not the case, I'd like to find out how myself also! :cheers:Nolift911 said:More importantly what did you do to the angel eyes - stock are really yellow
-jeff
Sean,SeanMD said:I'll second this question, apparently US models can swap out the LED's in the rings (at least it looks like it). I had thought that something to do with the euro versions could only swap out the LED's but if that's not the case, I'd like to find out how myself also! :cheers:
Sean
