Status
Not open for further replies.
1 - 19 of 19 Posts
~Just $65 plus $15 shipping~
Product Description
<HR>
These are brand new single beam 35W HID Xenon Conversion Kit. Single beam kits are low beam or high beam only. This kit contains everything you need to upgrade your existing car's headlight system to the best lighting technology available today!
  • 100% water proof construction, you can submerge the entire kit under water and it will function correctly
  • Integrated one piece Ballast, simplified wiring which eliminates any unnecessary confusion during install.
  • More than 16+ bulb types, we will have the right bulb type for your vehicle
  • 0.2% failure rate, compared to 5-10% failure rate of other HID Conversion kits currently out on the market, the reliability is comparable to that of OEM HIDs
  • Color temperature output has tolerance of +/- 100K, the tolerance is unnoticeable by human eyes
  • Superior lumen output compare to its competitor
  • Best quality burners from Bosch Japan
  • Choose from 7 different color temperature, you will indefinitely find the color out put of your choice
What is Included in our Kits:​
<HR align=center>
2 x Xenon HID Bulbs
2 x Digital HID Ballasts
2 x Double side tape
10 x Zip Tie
Installation Manual
All Necessary Wiring and Connectors
(Certain cars might require a relay harness and or canceller, sold separately
<HR>
Kit Specifications:​
<HR>
  • Power consumption: 35watts
  • Voltage: 85V +/- 17V
  • Luminous flux: 2800~3200lm
  • Service Life: up to 3000hrs
  • Input Voltage: 9V-16V
  • Working current (Steady state): 3.5 A nom
  • Ignition voltage: 24kV Peak Max, 18kV Peak Min
  • Lamp Frequency: 450 Hz
Feature
<HR>
All of our HID products are E4 and ISO-9001:2000 Approved. They are manufactured under the strictest of quality control. The ballasts are also shockproof and 100% waterproof (you can literally submerge the entire kit and it will still function properly).
Installation is Plug-N-Play and is simple enough for a first time installer to do in 20-30 minutes. Our kits plug right into your existing headlight assembly and all necessary hardware for installation is included.
Upgrade from the standard Halogen to the most advanced lighting technology today!
What are HIDs?
HID (High Intensity Discharge) refers to lighting technology that relies on an electrical charge to ignite xenon gas contained in a sealed bulb. A normal halogen bulb uses a filament which can burn out in as little as 200 hours. HID bulbs are gas filled capsules that are rated for a lifespan of nearly 4500 hours. HID bulbs also shine much brighter due to this technology.
Unlike halogen bulbs, HID's emit a type of light that closely resembles natural daylight and is therefore much easier on human eyes. In fact, HID lights are currently used in most sports arenas, stadiums, and train stations worldwide. Don't be fooled by lower end Xenon replica bulbs sold at most retail shops. They are no match for the intensity, purity, and efficiency of high intensity discharge headlights.
Benefits of HID's:
  • LASTS UP TO 10X LONGER THAN THE TRADITIONAL HALOGEN BULBYOU ARE CURRENTLY RUNNING IN YOUR CAR
  • HID (5000K) WILL GIVE YOU A NATURAL WHITE LIGHT THAT IS SOFT ON YOUR EYES AND YET INTENSIVE (3 TIMES BRIGHTER THAN HALOGEN) ENOUGH TO LET YOU SEE OBSTICALS 1/4 MILE IN FRONT OF YOU GIVING YOU MUCH MORE REACTION TIME, THUS MAKING YOUR NIGHT TIME DRIVING MUCH SAFER.
  • DRAMATICALLY ENHANCE THE LOOK OF YOUR HEADLIGHTS. WITH CHOICES OF DIFFERENT COLOR TEMPERATURES (K), HID'S WILL GIVE YOUR CAR THE AGREESIVE LOOK OR THE LUXURY CAR LOOK YOU ALWAYS WANTED!
  • EASY INSTALL! MOST OF THE APPLICATION WILL BE 100% PLUG AND PLAY AND IT IS AS EASY AS REPLACING YOUR HEADLIGHT BULBS.
  • INSTALL WILL BE AS EASY AS 1 2 3. SIMPLY TAKE OUT YOUR HALOGEN BULBS FROM YOUR HEADLIGHT HOUSING AND REPLACE IT WITH THE HID BULBS, CONNECT THE HID BULBS TO THE BALLAST, AND CONNECT THE BALLAST TO THE FACTORY HARNESS, YOU ARE DONE!
  • 100% WATER AND WEATHER PROOF, YOU CAN SUBMERGE THE ENTIRE KIT IN TO WATER AND IT WILL FUNCTION AND OPERATE NORMALLY!
Please Select a Bulb Type and Color
<HR>
Bulb Sizes Available:
H1, H3, H4(low), 9003(low) ,HB2(low) , H6, H6m, H7, H8, H9, H10, 9145, 5202, H11, H13(low), 9008 (Low), 880/881 (All 800 series), 9004(low), HB1(Low), 9005, HB3, 9006, HB4, 9007(low), HB5 (Low), D2S, D2R, D2C, 5202. Please note: this is a single beam kit not a hi/low kit
If you are uncertain about your bulb type, please refer to the following link:
http://www.sylvania.com/ConsumerProducts/AutomotiveLighting/LampReplacementGuide
Color Temperature Available:
3000K(Yellow), 5000K(White), 6000K(Diamond White), 8000K(Blue), 12000K(Violet Blue), 30000K(Pink/ Violet), and GREEN (NEW!).
Warranty Information
<HR>
All of our HID Conversion Kits, HID Bulbs, and Digital Ballasts are covered by a 2-Year Warranty. The warranty covers any factory defects with the bulbs and ballasts. If the product stops working within 2 years from the date you purchased it, send it back to us and we will replace the defective item. It's as easy as that! Keep in mind that our defective rate on HID Kits and parts is less than 0.3% (yes, less than 1%!) so you can buy with confidence.
If you are interested in purchasing one of the kits, please email me @ [email protected].
<HR>
  • <LI class=style1>EMAIL: <LI class=style1>BULB TYPE:
    [*]COLOR TEMPERTURE:
How are you shipping these kits? fedEx?
I can do a flat rate box for $5.20 but it may take a few more days to arrive. If your putting them in m5 fog lights, there hb4s or 9006 bulbs. I have 10000k lights in my headlights and fog lights
I can do a flat rate box for $5.20 but it may take a few more days to arrive. If your putting them in m5 fog lights, there hb4s or 9006 bulbs. I have 10000k lights in my headlights and fog lights<!-- google_ad_section_end -->
I'll email you - thanks for the quick responses
No hid should if your car came with hids. it's in the Lcm coding - no cold check.
Ok..so easy then...guess my question to you Mr. drift-wizard is 35 w v. 55 w ....so this will be lower output I guess right?
For cheap 3rd-world produced kits like this, go 55w. I would go through someone like ddmtuning add they offer lifetime warranties on their kits. While their customer support is slow, they are more likely to remain around when compared with someone schlepping the same quality kits through forum classifieds.
What about going with HID fogs, car came with halogen fogs I believe.
Mine came with halogen at least . . .I need to review some of the older posts - I know they are here and I have read them a couple times just cannot remember details anymore.
Plus the DDM tuning ones I think are around $35-40 bucks so paying more for these does not make sense, esp when we don't know how they will work and last. These guys need to be more competitive unless they offer a far superior product then DDM which I highly doubt.
1 - 19 of 19 Posts
Status
