1 - 12 of 12 Posts
<table id="HB_Mail_Container" unselectable="on" border="0" cellpadding="0" cellspacing="0" height="1181" width="370"><tbody><tr width="100%" unselectable="on" height="100%"><td id="HB_Focus_Element" unselectable="off" background="" height="250" valign="top" width="100%">Hi all
need some help as i keep on getting the same fault codes.
las
t week i had both pre cat sensors changed as i was getting poor mpg.after haveing them changed i pluged in peak tool and got codes 90 fuel control cyl 1-4
91 fuel control cyl 5-8
cleared codes and since i have driven about 150 miles . the car runs great .no problems.
today checked codes and found the same codes 90 /91.
in the last 3k miles i have had new mafs , all 4 cam sensors , and most recently pre cat sensors.
any ideas why i am geting codes?
</td></tr></tbody></table>
Discussion Starter · #2 ·
<TABLE id=HB_Mail_Container height="100%" cellSpacing=0 cellPadding=0 width="100%" border=0 UNSELECTABLE="on"><TBODY><TR height="100%" width="100%" UNSELECTABLE="on"><TD id=HB_Focus_Element vAlign=top width="100%" background="" height=250 UNSELECTABLE="off">sorry post is so far down page.
</TD></TR><TR UNSELECTABLE="on" hb_tag="1"><TD style="FONT-SIZE: 1pt" height=1 UNSELECTABLE="on">
</TD></TR></TBODY></TABLE>
Do you have a SES light come out?try clearing them (Codes) again and see if they come back, sometimes your ecu is still adapting, try checking your fuel filter aswell ...hope this helps
<TABLE id=HB_Mail_Container height="100%" cellSpacing=0 cellPadding=0 width="100%" border=0 UNSELECTABLE="on"><TBODY><TR height="100%" width="100%" UNSELECTABLE="on"><TD id=HB_Focus_Element vAlign=top width="100%" background="" height=250 UNSELECTABLE="off"></TD></TR><TR UNSELECTABLE="on" hb_tag="1"><TD style="FONT-SIZE: 1pt" height=1 UNSELECTABLE="on">
no ses light
forgot to mention fuel pump and fillter have also been changed.
have cleared codes . will check them after a few days and see what hapends.
Check for intake vacuum leak aswell...btw you don't have SES light? and you still manage to pull the codes 90/91, you probably did not reset/ erase your codes...
<table id="HB_Mail_Container" unselectable="on" border="0" cellpadding="0" cellspacing="0" height="100%" width="100%"><tbody><tr width="100%" unselectable="on" height="100%"><td id="HB_Focus_Element" unselectable="off" background="" height="250" valign="top" width="100%">where do i check for vacum leaks? can i do this my self or do i need to take to dealer.
</td></tr><tr unselectable="on" hb_tag="1"><td style="font-size: 1pt;" unselectable="on" height="1">
His car is probably European spec. No SES light system. I usually pull codes from my car; I have never seen SES light. I have the same codes he is having and never found the cause so I left it<O:p</O:p
Hi guys i've just got these codes too but i've also just got 2 other ones
0A = Exhaust Camshaft Position Sensor , Cyl #1-4
0F = Crankshaft/Camshaft position correlation Cyl #1-4
Admittedly i did run the car low on fuel on Sunday but i've run it that close before without getting codes.
The other 2 codes seem like a CPS is about to fail, is that a correct assumption?
Fuel control codes are an interesting problem. I've been getting these on occasion. The simple interpretation is fuel filter/pump or something with the fuel delivery. However, I've checked these and have yet to pen down the source.
What might be helpful is to know exactly what input/sensor the DME is responding to to trip this code. I wish we had a master book that tells us exactly what sensor input the DME is monitoring for each code... this might help us better understand them, as well as collateral code scenarios.
Sure smells like it! Usual procedure is to clear and confirm their return. Then start reading up on CPS replacement. :)
Dave
Cleared the codes soon as i'd read them, just took the car out for a drive (10 - 15 miles approx) no codes returned. It is quite short so i'll read them again sometime early next week.
1 - 12 of 12 Posts
