1 - 4 of 4 Posts
Hey guys I’m getting this problem on my bmw m6 2006. When putting to reverse it’s putting me back to neutral as u see in the video below the only way I can reverse is when I put the car to neutral it’s really weird... the code for the problem is 5002 selector lever... any ideas what it could be??
Apparently the selector lever module itself can crap out and cause issues where the trans doesn't know what gear you're trying to put it in. May be worth just removing to check and clean the connections and wiring then reinstall to see if that makes a difference.
Good Luck!
Good Luck!
Thanks man i will have a look into that!
Yes, it seems you lever is malfunctioning. As soon you move it to the left it shows R, it should show R when put in R.
Do as the previous post.
1 - 4 of 4 Posts
