1 - 5 of 5 Posts
2006 BMW E60 M5 S85
Hi gays
2006 E60 M5
I have some problems with the new wheels there is some vibration while driving.
I searched and found it needs some rings and sperce and the problem is gone. I found some measurements but can't decide which size is right for me
Wheel Spacer & Bolt Kit - 20mm
Hub Centric Rings
Is this a match?
thanks a lot
Yes you need 72.56 for the e60 m5 hubs. What wheels did you get? You need to make sure those matches your wheels as well or it still won't center. What's the bore size of your wheels and what wheels did you get
I may have a set I can give you if you have the same bore size. I got several of these rings before after trying different wheels over the years.
2006 BMW E60 M5 S85
thank you very much my friend
The wheels I bought (Chinese Class A) have 10mm rings with me but caused a vibration while driving.
I need to take a picture of the current wheels and know their size
Take a look at the picture. These are the current wheels size:
Front: 19``-8.5
Rear: 19 "9.5
The wheels are in the M6, not the M5
947121
I don't know anything about 10mm rings you will need to see what the hub bore hole in the center of your wheels measure
2006 BMW E60 M5 S85
Thanks my friend can you see my photos i resize my wheels measure
947199
947200
1 - 5 of 5 Posts
