1 - 4 of 4 Posts
Hi all,I have a E39 M5 and the connector for the memory seat button has been smashed so now all I have are some loose wires with no connector attached ,a call to the dealers and I can buy a new connector but they said that they can't get the wiring diagram to let me put the wires in the correct pin .
can a kind member please pull out their memory seat buttons and post a clear pic of the order that the wires are in the connector ,many thanks :M5thumbs:
Hi Bleek,
The wiring diagram can be found in WDS. As for WDS itself, that can be found online here: WDS BMW Wiring Diagram System - 5 E39 12/95 - 09/98
I attached the wiring diagram as a PDF, and the pin assignments as a JPEG.
Hopefully that's everything you need to get your connector pieced back together :cheers:
Try this.
Looking at the face of the plug below, the colours of the wires that connect at the rear of the plug are as follows:
Top left - Grey/Blue
Top right - Brown/White
Middle left - Brown
Middle right - Brown/Yellow
Bottom left - Grey/Red
Bottom right - Green/Brown
Bear in mind that when you look at the rear of the plug, top and bottom are the same but left and right will be reversed. Hope all this makes sense!
Reactions: bleek
1 - 4 of 4 Posts
