Can you please post a photo of your splitters.phillym5 said:I bought it used, so no instructions. My splitter already has the holes for the screws, but the splash guard under the car is pretty thick. Your splitters look like their flush with the bottom of the bumper. If i dont cut the splash guard, there will be about 1.5 inch gap between the splitter and the bumper.. thanks Black.
josh.
Thanks for the photo. You have a different item from what Black M5 has installed. Black M5 has 2 front splitters, while you have an undertray front lip that Hamann calls "Front Spoiler - Competition." Your piece is 20% more expensive.phillym5 said:Beastpower,
here it is.
Josh, I would definitely just wing it. If you want a clean and durable install, I would first remove the front bumper, and then make sure the splitter is screwed in from both the outside and the inside of the bumper. You can also use 3M high-strength double-sided tape to add strength to the installation.phillym5 said:Beastpower,
Any chance you can get some instructions?
Or should i just "wing it"?
I assumed it was basically the same install as Blacks flippers. But, i dont know that install either.
thanks,
josh.
