1 - 5 of 5 Posts
My right side mirror is not coming back to normal position after tilting :( , I would like to check inside mirror mechanism for some loose gears..etc.
I know some guys have had a same problem.
Thanks in advance for help.
I would recommend first trying to manually slide the mirror down to the natural rest position when the left side mirror is also down. Then try the button and see if it comes up and down properly. That usually works.
iMac, I will have to agree with Anzir. I had a similar problem although it was actually that one mirror would not go up as opposed to one that does not go down. Manual manipulation should help.
I just hope that that is the only thing that does not go down!! hiha hiha
Pip :hihihi:
Pip :hihihi:
My dealer has a new motor on order for the same problem.
:cheers:
:1: :1:
Mirror always goes up but never down , when I help with hands it's very easy:confused2 .
Other thing goes down faster then up :sad1:
:biggrin:
1 - 5 of 5 Posts
