Re: Help ..!! Brake Vibration on hard breaking only ..
Try bedding the brakes to see if the problem is reduced or eliminated. See: http://zeckhausen.com/bedding_in_brakes.htm for step-by-step instructions. If bedding doesn't cure the problem, you either need to have your rotors turned or replaced.
Rotor thickness variation as the result of uneven brake pad transfer layer.J Irwan said:
