1 - 20 of 61 Posts
So today randomly the car decided to develop a misfire. It appears to be the entire right bank (cylinders 1-5) of the engine. It happens randomly. No matter what mode the car is in or how fast or slow or stationary I am. I start the car and it starts fine. sounds good for a few moments then "Engine Malfunction Power Reduced" Redline drops to 4k car runs like SH (Poop). Code reader sows up w/ P300 P301, P302. Basically Cyls 1 and 2 misfire and multiple misfire. Any suggestions before I ship it back to texas and sue the dealer for my money back?
Well since it's multiple cylinders, I wouldn't think a stuck injector which is deadly on this car. A simple test would be to swap your ionic sensors from L to R, R to L and see if the miss fires go to cylinders 6 and 7 or bank 2. If so easy fix by buying a new sensor. They are located under the plastic covers on the top front of each head. Very common on these cars.
going to give that a shot tomorrow. Hopefully its something that simple. I was researching and found someone else who said the same thing.
So I've swapped coil packs from cylinder to cylinder as well as spark plugs. Swapped the Ionic Control Units from side to side. Still coming up w/ the exact same error codes for the exact same cylinders. Cylinders 1&2 misfire and cylinder 5 intermittently does the same.
Compression check is next. Get yourself a copy of INPA and monitor combustion quality on each cylinder while running. You can tell if the wiring harness to the coil packs has bad connections that way.
well its kind of screwed up that ive had the car for under 1k miles and its gonna cost me a crapload to fix. depends on what the dealer wants to do. I think they need to make it right.
im uploading a Youtube video right now so that hopefully u guys can give me an idea of what to try next.
Where did you buy it? A week in, I would be knocking on their door. INPA will show you the error log as well as the error history. ISTA/D (what the dealers use) will show/delete the error log, but not the error history. If you can find someone with INPA to pull the error *history* and show if errors occurred a large number of times more than you have seen them, then you have a case for intentional misrepresentation.
I had random misfires in all 5 cylinders on one bank which turned out to be a cut in the brake booster hose if I remember correctly, the only way I found out the issue was by doing a smoke test for leaks.
It's located at the rear of the manifold, I had a misfire and bad idle for 3 months but could never figure it out until I decided to do a smoke test and there it was.
Discussion Starter #14
I cant see anything like that. If its the hose thats on the bottom right under the intake mani at the back of the engine then its fine.
Discussion Starter #15
so im not 100% positive but I believe my #2 injector is stuck open. I pulled all coils and plugs and the #2 is wet while all others are dry? What do you guys think? IS there a way to fix the injector or must it be replaced?
Discussion Starter #19
im having a hard time getting the Intake Plenum off to access the injectors. is there a trick to it?
1 - 20 of 61 Posts
