I am finally getting around to doing some cosmetic things to the car after rectifying all the outstanding maintenance the previous owner ignored. I've searched countless threads but I'm not exactly sure what I have here. The ballasts are Hella, but I'm under the impression these are not my OEM housings as I was told that 2000 model headlights cannot be separated... as these can. Are they 2001 lights? The covers I know are DEPO (markings on the lens) but I just need to figure out what origin the 'back' section is.
Also, what type of HID bulb is this and can I use another bulb (say, from DDM) in place of it with the stock ballast? Is the stock ballast rated at a certain wattage? i.e. 35w or 55w?
I'm sure a ton of you have been through it - I found little bits of white plastic in the housing. Can anyone point me to a thread on how to replace the level adjusters? I didn't see any easy way to take the mechanism apart either...
I ordered the ML-030 CCFL angel eyes from DDM but they don't seem to fit like the dead ones I'm replacing (see pic) - they're slightly smaller in diameter. Previous owner mounted these in front of the glass pieces of the DEPO covers with some sticky stuff, does anyone else know what A/E kit will fit here the same way as the old ones do?
Thanks fellas.
Thanks fellas.
