1 - 11 of 11 Posts
Hello All,
I am planning on changing out my head gaskets due to the amount of white smoke coming from my exhaust. I was wondering if anyone knows what all I would need to change out both. I have the gaskets coming and a set of gaskets/seals for valve covers and whatnot. If there is anything else that I would need please let me know. Thanks in advance!!
You do not need to replace both gaskets.
However, you should get the head checked because sometimes it can warped and might require a bit of grinding. In addition, it would be a good idea to get the head polished as well.
If the head cannot be repaired you might need to find a used head.
If the head requires a lot of skimming you will need to use a couple of gaskets to fix the compression.
I would be highly surprised if the head can be skimmed. Generally if it is warped it needs to be replaced, not skimmed.
Good luck.
Good luck.
You can surface both the head and block deck within reason. Have done this a couple of times now, you just need to take into account changes in cc's of the CC as well as rod length and PTV clearance.
You seem to imply more compression is a bad thing ;) :grin
I've never heard of an S85 with a blown head gasket - aren't they all metal?
MLS, but yes. Would literally be the first blown gasket I've heard of. Are you losing coolant? How many miles on the engine? Oil Consumption? Tuned?
Coolant is fine, 132k, normal oil consumotion (about half a quart/mo), fully stock
If u don't have bubbles in the expansion tank, and your coolant looks like it should be looking (dark blue or blue if aftermarket then green) and you don't have milkshake - your head gasket is fine.
What you are experiencing is probably piston rings are worn or you have scratches on cylinder walls, or valve seals (which i don't think).
My bet is scratches on the cylinder walls and worn piston rings.
1 - 11 of 11 Posts
About this Discussion
7 Participants
Bucky
BMW M5 Forum and M6 Forums
Full Forum Listing
