1 - 7 of 7 Posts
Thanx Kev.
Do you know if the wiring is the same as the 535i (only diagram I have)as i'm getting the L/H indicator running when ever the ignition is on, ie all the time (R/H works normally) :grrrrr:
I think for the indicators it will be the same but I can't 100% sure. As you would expect a lot of the wiring is the same.
OK guys.. update time..
Had to get the local auto sparky to sort this one out, turns out that some soldered connections had got too hot in the LKD(light control module) and the solder from the hot joint had bridged the indicator circuit connections making it permanently on....were talking level 9 gremlins :mad: here. Lucky for me my sparky knows what to look for eh...
So thats this one dead and buried for now :hihi:
1 - 7 of 7 Posts
